Saltar al contenido principal
HP Pavilion 17 TS Rear Cover Replacement
Sean Croft
Sean Croft y otro contribuidor
Última actualización: May 25, 2016
30 segundo
Fácil
Necesita mejores imágenes
Introducción
Ir al paso 1
The rear plate acts like a shield. It protects your most important components from outside interference, like damage and to some extent, dust. This guide will show you how to remove it.
Qué necesitas
Herramientas
  1. HP Pavilion 17 TS Rear Cover Replacement, Battery: paso 1, imagen 1 de 3 HP Pavilion 17 TS Rear Cover Replacement, Battery: paso 1, imagen 2 de 3 HP Pavilion 17 TS Rear Cover Replacement, Battery: paso 1, imagen 3 de 3
    • Press and hold the release switch, and then slide the battery out. Insert the new battery into the slot and you're done!
  2. HP Pavilion 17 TS Rear Cover Replacement, Rear Cover: paso 2, imagen 1 de 3 HP Pavilion 17 TS Rear Cover Replacement, Rear Cover: paso 2, imagen 2 de 3 HP Pavilion 17 TS Rear Cover Replacement, Rear Cover: paso 2, imagen 3 de 3
    • In the battery compartment, find the phillips screw that is holding the rear panel onto the computer. Unscrew it.
    • With the battery compartment closest to you, push the panel away from you. Once it slides back until it stops, gently lift it and put it to the side.
    • Please note that this particular screw does not completely come out, it stays with the rear panel and that is ok.
Conclusión
Sean Croft
Miembro Desde 03/25/16
739 Reputación
5 Guías creadas
Equipo
UMass Dartmouth, Team 1-6, Miles Spring 2016 Miembro de UMass Dartmouth, Team 1-6, Miles Spring 2016
UMASSD-MILES-S16S1G6
Miembros de 3
9 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 463
