HP Envy x360 15m-bq121dx Cooling Fan Replacement
Introducción
Ir al paso 1The cooling fan is a key component of a laptop. This component keeps the computer cool while operating. If the fan fails, the computer may overheat and damage components in the computer. This guide will show in-depth steps on how to safely remove a cooling fan from an HP Envy x360.
Qué necesitas
Partes
Herramientas
Ver más…
Remove the rubber strip along the top of the backside of the computer.
On the back panel of the device, remove the four (4) 2.5 mm screws at the top of the photo using a Phillips #0 screwdriver.
Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
