Saltar al contenido principal
HP Envy x360 15m-bq121dx Cooling Fan Replacement
Fabien Perez
Fabien Perez y 5 otros contribuidores
Última actualización: May 7, 2024
5 - 15 minutos
Moderado
Necesita más imágenes
Introducción
Ir al paso 1
The cooling fan is a key component of a laptop. This component keeps the computer cool while operating. If the fan fails, the computer may overheat and damage components in the computer. This guide will show in-depth steps on how to safely remove a cooling fan from an HP Envy x360.
Qué necesitas
Partes
Herramientas
Ver más…
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. HP Envy x360 15m-bq121dx Cooling Fan Replacement, Cooling Fan: paso 1, imagen 1 de 2 HP Envy x360 15m-bq121dx Cooling Fan Replacement, Cooling Fan: paso 1, imagen 2 de 2
    • Be sure the computer is powered off.
    • Remove the rubber strip along the top of the backside of the computer.
    • On the back panel of the device, remove the four (4) 2.5 mm screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq121dx Cooling Fan Replacement: paso 2, imagen 1 de 3 HP Envy x360 15m-bq121dx Cooling Fan Replacement: paso 2, imagen 2 de 3 HP Envy x360 15m-bq121dx Cooling Fan Replacement: paso 2, imagen 3 de 3
    • To remove the back cover, use the spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
    • Be sure to not damage any of the electronics on the inside.
  3. HP Envy x360 15m-bq121dx Cooling Fan Replacement: paso 3, imagen 1 de 1
    • Use the Philips #0 screwdriver to remove seven 2 mm screws from battery.
  4. HP Envy x360 15m-bq121dx Cooling Fan Replacement: paso 4, imagen 1 de 1
    • Lift and pull the front of the battery up and out away from the connector to remove.
  5. HP Envy x360 15m-bq121dx Cooling Fan Replacement: paso 5, imagen 1 de 2 HP Envy x360 15m-bq121dx Cooling Fan Replacement: paso 5, imagen 2 de 2
    • Using a Philips #0 screwdriver, remove the three 2 mm screws located around the cooling fan as shown in this picture.
    • The fan may have sharp edges so be careful upon removal.
  6. HP Envy x360 15m-bq121dx Cooling Fan Replacement: paso 6, imagen 1 de 2 HP Envy x360 15m-bq121dx Cooling Fan Replacement: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Remove the connector clip with the tweezers.
  7. HP Envy x360 15m-bq121dx Cooling Fan Replacement: paso 7, imagen 1 de 1
    • Remove the four spring loaded screws with a Philips #1 screwdriver.
  8. HP Envy x360 15m-bq121dx Cooling Fan Replacement: paso 8, imagen 1 de 2 HP Envy x360 15m-bq121dx Cooling Fan Replacement: paso 8, imagen 2 de 2
    • Remove the cooling fan.
Conclusión
Fabien Perez
Miembro Desde 02/13/20
157 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 16
Todo El Tiempo: 2,063
