HP Envy x360 15m-bq021dx Motherboard Replacement
Introducción
Ir al paso 1Follow this guide to replace the motherboard of your HP Envy x360 15m-bq021dx. A motherboard is the “heart” of the computer. It is also known as the primary printed circuit board. This engages all of the computer’s components, allowing the computer to operate. This guide will show in-depth details on how to safely remove a motherboard.
On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
Using a Philips #0 screwdriver, remove the three M2x4 screws located around the cooling fan as shown in this picture.
Using a Phillips #1, remove the seven M2.0x3.2 screws.
Undo the six connections using the blue opening tool.
2 personas más completaron esta guía.
Un comentario
hi so i was woundering about the start button , mine is broken , is there a way to start uo the pc and can i hook up a poer button some how to start it up thanks
