Saltar al contenido principal
HP Envy dv6-7363cl Wi-fi Card Replacement
dylananthony
dylananthony y 3 otros contribuidores
Última actualización: May 7, 2024
3 minuto
Fácil
Introducción
Ir al paso 1
Reader will be able to successfully replace their Wi-Fi card in the device. A basic understanding of simple tools such as a screwdriver is needed. Any form of electricity must be removed from device, including the charging cable and battery.
Qué necesitas
Partes
Herramientas
Ver más…
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. HP Envy dv6-7363cl Wi-fi Card Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the device upside-down so that its bottom is facing up.
  2. HP Envy dv6-7363cl Wi-fi Card Replacement: paso 2, imagen 1 de 1
    • Push the lever underneath the battery to the left.
  3. HP Envy dv6-7363cl Wi-fi Card Replacement: paso 3, imagen 1 de 2 HP Envy dv6-7363cl Wi-fi Card Replacement: paso 3, imagen 2 de 2
    • Lift the battery up out of its socket.
  4. HP Envy dv6-7363cl Wi-fi Card Replacement, Wi-Fi Card: paso 4, imagen 1 de 1
    • After removing the battery, remove the circled screw.
  5. HP Envy dv6-7363cl Wi-fi Card Replacement: paso 5, imagen 1 de 1
    • Remove the back cover.
  6. HP Envy dv6-7363cl Wi-fi Card Replacement: paso 6, imagen 1 de 1
    • With the back cover removed, locate the Wi-Fi card which is positioned next to the Beats logo.
  7. HP Envy dv6-7363cl Wi-fi Card Replacement: paso 7, imagen 1 de 2 HP Envy dv6-7363cl Wi-fi Card Replacement: paso 7, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Carefully remove gold-headed, black wires from Wi-Fi card with tweezers.
  8. HP Envy dv6-7363cl Wi-fi Card Replacement: paso 8, imagen 1 de 2 HP Envy dv6-7363cl Wi-fi Card Replacement: paso 8, imagen 2 de 2
    • After removing wires, remove circled screws from card.
    • Note: Laptop shown only has one screw holding in Wi-Fi card. Some models may have both.
  9. HP Envy dv6-7363cl Wi-fi Card Replacement: paso 9, imagen 1 de 2 HP Envy dv6-7363cl Wi-fi Card Replacement: paso 9, imagen 2 de 2
    • Wi-Fi card will raise out of device when screw is removed.
    • Gently pull card to the right to remove from device.
Conclusión
Una persona más ha completado esta guía.
dylananthony
Miembro Desde 10/20/16
564 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 415
