Saltar al contenido principal
HP Envy X2-15-C001Dx Hard Drive Replacement
Dylan Hathaway
Dylan Hathaway y 6 otros contribuidores
Última actualización: June 22, 2022
10 - 20 minutos
Fácil
Introducción
Ir al paso 1
This guide will explain how to remove and replace the hard drive in the HP Envy X2-15-C001Dx.
The hard drive is the part of the computer that stores and retrieves data. Replacing the hard drive can solve different problems such as irregular noises and computer crashes.
Be sure to back up your hard drive before replacing.
Qué necesitas
Herramientas
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
Ver más…
  1. HP Envy X2-15-C001Dx Hard Drive Replacement, Back Panel: paso 1, imagen 1 de 1
    • Place the laptop face down on a table.
  2. HP Envy X2-15-C001Dx Hard Drive Replacement: paso 2, imagen 1 de 2 HP Envy X2-15-C001Dx Hard Drive Replacement: paso 2, imagen 2 de 2
    • Lift up the back stand.
  3. HP Envy X2-15-C001Dx Hard Drive Replacement: paso 3, imagen 1 de 2 HP Envy X2-15-C001Dx Hard Drive Replacement: paso 3, imagen 2 de 2
    • Remove the five screws from the bottom of the back plate using a Phillips #1 screwdriver.
  4. HP Envy X2-15-C001Dx Hard Drive Replacement: paso 4, imagen 1 de 1
    • Remove four screws from the back stand hinges using a Phillips #1 screwdriver.
  5. HP Envy X2-15-C001Dx Hard Drive Replacement: paso 5, imagen 1 de 2 HP Envy X2-15-C001Dx Hard Drive Replacement: paso 5, imagen 2 de 2
    • Remove the hinges and the back stand from the laptop.
  6. HP Envy X2-15-C001Dx Hard Drive Replacement: paso 6, imagen 1 de 1
    • Use a spudger to remove the thin panel where the back stand was.
  7. HP Envy X2-15-C001Dx Hard Drive Replacement: paso 7, imagen 1 de 1
    • Remove the screws from the back panel using a Phillips #1 screwdriver.
  8. HP Envy X2-15-C001Dx Hard Drive Replacement: paso 8, imagen 1 de 2 HP Envy X2-15-C001Dx Hard Drive Replacement: paso 8, imagen 2 de 2
    • Remove two side screws using a Phillips #1 screwdriver.
  9. HP Envy X2-15-C001Dx Hard Drive Replacement: paso 9, imagen 1 de 2 HP Envy X2-15-C001Dx Hard Drive Replacement: paso 9, imagen 2 de 2
    • Pry apart the base from the screen by going around the entire perimeter with an opening tool.
  10. HP Envy X2-15-C001Dx Hard Drive Replacement: paso 10, imagen 1 de 2 HP Envy X2-15-C001Dx Hard Drive Replacement: paso 10, imagen 2 de 2
    • Remove the back panel from the laptop.
  11. HP Envy X2-15-C001Dx Hard Drive Replacement, Hard Drive: paso 11, imagen 1 de 3 HP Envy X2-15-C001Dx Hard Drive Replacement, Hard Drive: paso 11, imagen 2 de 3 HP Envy X2-15-C001Dx Hard Drive Replacement, Hard Drive: paso 11, imagen 3 de 3
    • Lift the hard drive out from its slot, taking care not to tear the ribbon cable that is connecting it to the motherboard.
    • Unplug the hard drive from the motherboard.
    • Completely remove the hard drive from the laptop.
Conclusión
2 personas más completaron esta guía.
Equipo
UMass Dartmouth, Team 2-6, Sinclaire Fall 2021 Miembro de UMass Dartmouth, Team 2-6, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G6
Miembros de 3
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 19
Todo El Tiempo: 755
