HP Envy TouchSmart 15 Solid State Drive Replacement
Introducción
Ir al paso 1You should replace your solid state drive if it has become damaged or corrupted. The OS will not boot properly is a major system of this.
Qué necesitas
Herramientas
Remove the single screw holding the accessory plate. This is a PH0 2.0x2.5 screw.
Remove the PM 2.0x2.5 screw with the PH#0 Screwdriver attachment that is shown at the corner of the Solid State Drive.
After you have removed the screw, the Solid State Drive should lift up.
4 personas más completaron esta guía.
2 comentarios
Please what type of ssd is that and can i get the specifications? I want to get one for my laptop since it didn’t ship with it. Its the same as the one above. HP ENVY TS 15 Notebook PC Thanks.
Wht type of ssd i can insert here
Plz help me
