Saltar al contenido principal
HP Envy 17-J013CL Processor Replacement
Matt McBride
Matt McBride y otro contribuidor
Última actualización: April 17, 2017
15 minuto
Moderado
Introducción
Ir al paso 1
The CPU plays the most important part to the laptop's system as it is where everything is done. The most important part is also the most easy to be broken so a lot of care must be taken in order to fix this! Keep yourself grounded and do not bend the pins!
Qué necesitas
Herramientas
  1. HP Envy 17-J013CL Processor Replacement, Battery: paso 1, imagen 1 de 1
    • Lay the laptop with the battery facing towards you.
    • Remember to disconnect the AC cable and other power sources from the device before replacing/repairing parts.
  2. HP Envy 17-J013CL Processor Replacement: paso 2, imagen 1 de 1
    • Grab hold of the small battery slider and apply pressure to the right.
    • The laptop itself will push the battery out for you once the switch slides all the way to the right.
  3. HP Envy 17-J013CL Processor Replacement: paso 3, imagen 1 de 3 HP Envy 17-J013CL Processor Replacement: paso 3, imagen 2 de 3 HP Envy 17-J013CL Processor Replacement: paso 3, imagen 3 de 3
    • Pull the battery out and let go of the battery slider.
  4. HP Envy 17-J013CL Processor Replacement, Back Panel: paso 4, imagen 1 de 2 HP Envy 17-J013CL Processor Replacement, Back Panel: paso 4, imagen 2 de 2
    • Use a PH1-screwdriver to loosen the 7mm screw. The screw will not fully come out as it is held by a washer underneath but will come out enough to open it.
  5. HP Envy 17-J013CL Processor Replacement: paso 5, imagen 1 de 1
    • Gently pull the back panel off starting from the battery side towards the back.
    • Pull it back as it snaps out of the holding sockets.
    • It is preferred to use both hands when pulling the back panel off to prevent bending it out of shape.
  6. HP Envy 17-J013CL Processor Replacement, Processor: paso 6, imagen 1 de 3 HP Envy 17-J013CL Processor Replacement, Processor: paso 6, imagen 2 de 3 HP Envy 17-J013CL Processor Replacement, Processor: paso 6, imagen 3 de 3
    • Locate the 7mm screw for the optical drive right next to the WLAN and Memory modules.
    • Remove the screw with a PH1-screwdriver to release the CD-drive.
  7. HP Envy 17-J013CL Processor Replacement: paso 7, imagen 1 de 3 HP Envy 17-J013CL Processor Replacement: paso 7, imagen 2 de 3 HP Envy 17-J013CL Processor Replacement: paso 7, imagen 3 de 3
    • Use a PH1-Screwdriver to remove all the 7mm screws.
    • Use a PH0-Screwdriver to remove the 3mm screws.
    • Use the same PH0-Screwdriver for the 2mm screws.
  8. HP Envy 17-J013CL Processor Replacement: paso 8, imagen 1 de 2 HP Envy 17-J013CL Processor Replacement: paso 8, imagen 2 de 2
    • Pull the under panel from the laptop by pulling at the edges once all screws are removed. Gently lift it off and place to the side.
  9. HP Envy 17-J013CL Processor Replacement: paso 9, imagen 1 de 1
    • Unscrew the coiled springs indicated in red from the the motherboard.
    • Remove the 7mm screws with a PH1-screwdriver to loosen the fan.
    • Unplug the fan from the motherboard.
  10. HP Envy 17-J013CL Processor Replacement: paso 10, imagen 1 de 1
    • Lift the fan out and then lift out the black grill covering the processor.
  11. HP Envy 17-J013CL Processor Replacement: paso 11, imagen 1 de 2 HP Envy 17-J013CL Processor Replacement: paso 11, imagen 2 de 2
    • Use a Flathead screwdriver to turn the screw 180 degrees to unlock the processor from the motherboard.
    • Gently and vertically lift the processor out.
    • When placing the processor chip back in, make sure the golden triangle is on the top-left corner of the motherboard slot.
    • Be careful not to bend the pins on the processor chip. Broken pins will render the chip useless.
Conclusión
Una persona más ha completado esta guía.
Matt McBride
Miembro Desde 02/02/17
872 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 16-6, Blackwell Spring 2017 Miembro de USF Tampa, Team 16-6, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G6
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 1,015
