Saltar al contenido principal
HP Envy 15-J120SG Display Panel Replacement
Christian
Christian y otro contribuidor
Última actualización: January 7, 2019
2 hora
Moderado
Guía aportada por comunidad
Introducción
Ir al paso 1
The left third of my Display had stripes which appear and disappear when I press various parts of the Laptop. After opening up the laptop it became apparent, that the LCD Panel was to blame. I replaced it.
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
Resumen del Video
  1. HP Envy 15-J120SG Display Panel Replacement, Remove the Service Door and the Hard Drive: paso 1, imagen 1 de 2 HP Envy 15-J120SG Display Panel Replacement, Remove the Service Door and the Hard Drive: paso 1, imagen 2 de 2
    • Remove one screw to access the service port.
    • Remove the Hard Drive and the Little cable, connecting the HD to the Motherboard.
  2. HP Envy 15-J120SG Display Panel Replacement, Remove a lot of screws and the base enclosure: paso 2, imagen 1 de 2 HP Envy 15-J120SG Display Panel Replacement, Remove a lot of screws and the base enclosure: paso 2, imagen 2 de 2
    • Remove the two rubber feet on the front.
    • Remove eight screws. The Manual says seven, but in my Laptop there was an additional screw hidden under a sticker on the lower side.
    • Remove seven 1,6x2 screws from the battery compartment.
    • Remove three 2,5x3 screws from the HD area
    • Remove two screws: One near the small backup battery, the other one from the left part of the service bay.
    • Now you can remove the base enclosure.
  3. HP Envy 15-J120SG Display Panel Replacement, Remove three cables to the Display Unit: paso 3, imagen 1 de 1
    • Disconnect the black and white cable of the WLAN antenna. The position of the two cables is marked on the antenna PCB. Then remove both cables from their clips.
    • Disconnect the Display Cable and remove it from the clips.
    • Disconnect the cable from the camera and remove it from any clips.
  4. HP Envy 15-J120SG Display Panel Replacement, Remove the screws of the display hinges: paso 4, imagen 1 de 2 HP Envy 15-J120SG Display Panel Replacement, Remove the screws of the display hinges: paso 4, imagen 2 de 2
    • We have to remove the LCD Panel from the case. Otherwise we can't open the Display Lid properly and remove the LCD.
    • First remove two 2.5x4 screws from the left hinge.
    • Then remove one 2.5x6 and one 2.5x4 screw from the right hinge.
    • Now you can detach the LCD Unit from the rest of the case. Four cables should still be attached to the LCD: Two WLAN Antenna Wires (Black, White), the Display Cable and the Webcam Cable.
  5. HP Envy 15-J120SG Display Panel Replacement, Remove the display bezel: paso 5, imagen 1 de 2 HP Envy 15-J120SG Display Panel Replacement, Remove the display bezel: paso 5, imagen 2 de 2
    • Under the plastic of the bezel are two hidden screws: One is in the lower left corner, the other in the lower right corner. Bend the plastic up a bit and remove these screws.
    • The Bezel itself comes loose pretty easy as soon as you have disconnected it from the lower part on one point. Work your way around the display.
    • The bezel is glued to the display using double-sided tape. Be careful while lifting the plastic. When re-assembling the lid, place new double-sided tape on these places.
  6. HP Envy 15-J120SG Display Panel Replacement, Remove the Display Panel: paso 6, imagen 1 de 3 HP Envy 15-J120SG Display Panel Replacement, Remove the Display Panel: paso 6, imagen 2 de 3 HP Envy 15-J120SG Display Panel Replacement, Remove the Display Panel: paso 6, imagen 3 de 3
    • Remove four screws which hold the LCD panel in the Display Lid.
    • The LCD cable goes through one hinge. Remove the two screws, pull the LCD cable out and replace the hinge and the screws. So they will not get lost, you have enough screws already to care about.
    • Finally, the display panel is free.
  7. HP Envy 15-J120SG Display Panel Replacement, Diagnose and Ordering a new LCD: paso 7, imagen 1 de 2 HP Envy 15-J120SG Display Panel Replacement, Diagnose and Ordering a new LCD: paso 7, imagen 2 de 2
    • The cause of the flickering are these wires, which are bonded to the small PCB. The PCB takes the LVDS-Signals and de-multiplexes them into the 1900x1000 (or so) lines which drives the display. There are three of these connections below the Do not Touch-Area. One seems to be defect, so one third of the display is broken.
    • My Display is marked with 720557-001. This corresponds to the No Touch, Full HD Spare Part number in the Manual I have linked on the front page of this guide. I ordered mine from an ebay-dealer in the UK for 85€ incl. shipping. The name of the company is REQUIRE-IT and the delivered fast and the display is working.
  8. HP Envy 15-J120SG Display Panel Replacement, Replace LCD, quick test, assembly: paso 8, imagen 1 de 1
    • After your new display arrives remove the LVDS-wire from your old display and connect it to the new one. The display cable is secured with a sticker. Transfer this sticker from the old panel to the new one.
    • Do a quick sanity test. You onle need to connect the LVDS-cable and the power wire, then switch on the laptop.
    • If everythings works, re-assemble the laptop.
Conclusión
To reassemble your device, follow these instructions in reverse order. Take care to glue the bezel to the display on the green marked places in step 5.
6 personas más completaron esta guía.
Christian
Miembro Desde 03/09/14
1,560 Reputación
8 Guías creadas
Un comentario
Good guide but you can actually access the bottom display bezel screws in step 5 straight away.
You can remove these screws although a specific angle is required, this saves fully disassembling the laptop.
565jc565 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 16
Ultimos 30 días: 38
Todo El Tiempo: 9,332
