Saltar al contenido principal
HP Elitebook 8460p Keyboard Replacement
Garrett Anderson
Garrett Anderson y otro contribuidor
Última actualización: December 6, 2019
30 minuto
Moderado
Introducción
Ir al paso 1
If the keyboard is bad or malfunctioning, use this guide to replace the keyboard or check the keyboard connections on the inside of the laptop.
This guide requires a bit of prying to unsnap the keyboard from the laptop chassis. Following the instructions, pry carefully and do not force anything to avoid breaking any components.
The keyboard has two electrical connectors that attach to the motherboard. Before touching the connectors, make sure you are properly grounded to avoid damaging the motherboard itself.
To complete this guide you will need a Phillips #0 screw driver; an ESD strap; and a thin, sturdy plastic pry tool.
Qué necesitas
Partes
Herramientas
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
Ver más…
  1. HP Elitebook 8460p Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
  2. HP Elitebook 8460p Keyboard Replacement: paso 2, imagen 1 de 1
    • Slide the battery away from the switches until it can be lifted away from the laptop.
    • Lift the battery away from the laptop.
  3. HP Elitebook 8460p Keyboard Replacement, Back Panel: paso 3, imagen 1 de 1
    • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
  4. HP Elitebook 8460p Keyboard Replacement: paso 4, imagen 1 de 1
    • Slide the back shell of the laptop away from the switches until it can be lifted up.
    • Lift the shell straight up.
  5. HP Elitebook 8460p Keyboard Replacement, Keyboard: paso 5, imagen 1 de 3 HP Elitebook 8460p Keyboard Replacement, Keyboard: paso 5, imagen 2 de 3 HP Elitebook 8460p Keyboard Replacement, Keyboard: paso 5, imagen 3 de 3
    • Attach ESD strap around your wrist and to a ground.
    • Using a Phillips #0 bit, unscrew the two screws in front of the battery slot located on the bottom of the laptop.
  6. HP Elitebook 8460p Keyboard Replacement: paso 6, imagen 1 de 1
    • Flip the laptop over and open the screen.
  7. HP Elitebook 8460p Keyboard Replacement: paso 7, imagen 1 de 3 HP Elitebook 8460p Keyboard Replacement: paso 7, imagen 2 de 3 HP Elitebook 8460p Keyboard Replacement: paso 7, imagen 3 de 3
    • Using a spudger, work around the edge of the keyboard and pry it up from the device.
  8. HP Elitebook 8460p Keyboard Replacement: paso 8, imagen 1 de 2 HP Elitebook 8460p Keyboard Replacement: paso 8, imagen 2 de 2
    • Lift the keyboard out of the laptop and flip it over.
    • This exposes two different connectors. Both need to be detached in order to remove the keyboard. The larger connector is the main keyboard cable.
  9. HP Elitebook 8460p Keyboard Replacement: paso 9, imagen 1 de 2 HP Elitebook 8460p Keyboard Replacement: paso 9, imagen 2 de 2
    • Disconnect the keyboard cable on the laptop using a thin pry tool to open the connection.
    • Open the connection by inserting a thin plastic pry tool under the black tab in the connector and flipping it up.
  10. HP Elitebook 8460p Keyboard Replacement: paso 10, imagen 1 de 2 HP Elitebook 8460p Keyboard Replacement: paso 10, imagen 2 de 2
    • Using the spudger again, disconnect the thin ribbon strip on the back of the keyboard.
Conclusión
3 personas más completaron esta guía.
2 comentarios
There's a third keyboard screw right beside the fan
Colin Chaplin - Contestar
yeah just wanted to say this ...
Also the screws are PH1 not PH0
Robert Kohari -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 23
Ultimos 30 días: 42
Todo El Tiempo: 4,148
