Saltar al contenido principal
HP EliteBook x360 830 G6 CMOS Battery Replacement
Brody Reder
Brody Reder y 2 otros contribuidores
Última actualización: June 26, 2024
10 - 20 minutos
Fácil
Introducción
Ir al paso 1
This guide will instruct you on how to safely remove and replace CMOS battery in your HP Elitebook x360 830 G6. Excessive force to remove, or replace, any part should not be needed. If you find yourself straining to remove, or replace, a part, please review the steps to ensure you are doing it correctly. Proper storage of every part and screw is extremely important when completing this guide. When taking any hardware out of the laptop, place it safely off to the side as it will need to be reinstalled.
Qué necesitas
Partes
Herramientas
Ver más…
  1. HP EliteBook x360 830 G6 CMOS Battery Replacement, Unfasten the back cover: paso 1, imagen 1 de 1
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to loosen the five captive screws holding the back cover.
  2. HP EliteBook x360 830 G6 CMOS Battery Replacement, Release the clips: paso 2, imagen 1 de 2 HP EliteBook x360 830 G6 CMOS Battery Replacement, Release the clips: paso 2, imagen 2 de 2
    • Insert an opening pick between a corner of the back corner and the chassis, near a hinge.
    • Pry upward to release the retaining clips.
    • These clips will make an audible click when they release.
    • Repeat this process for the opposite corner.
  3. HP EliteBook x360 830 G6 CMOS Battery Replacement, Release the remaining clips: paso 3, imagen 1 de 2 HP EliteBook x360 830 G6 CMOS Battery Replacement, Release the remaining clips: paso 3, imagen 2 de 2
    • Insert your opening pick between the back cover and chassis, along the edge of the cover between the hinges.
    • Pry up to release the additional retaining clips.
  4. HP EliteBook x360 830 G6 CMOS Battery Replacement, Remove the back cover: paso 4, imagen 1 de 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, Remove the back cover: paso 4, imagen 2 de 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, Remove the back cover: paso 4, imagen 3 de 3
    • Grab the cover by the corners next to the hinges.
    • Swing the cover open and away from you.
    • If the back cover feels stuck to the chassis, use an opening pick to release remaining clips around the perimeter of the back cover.
    • Lift and remove the back cover from the laptop body.
  5. HP EliteBook x360 830 G6 CMOS Battery Replacement, Disconnect the battery: paso 5, imagen 1 de 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, Disconnect the battery: paso 5, imagen 2 de 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, Disconnect the battery: paso 5, imagen 3 de 3
    • Use the point of a spudger to push the sides of the battery connector out of its socket.
    • Push on alternate sides to "walk" the connector out.
  6. HP EliteBook x360 830 G6 CMOS Battery Replacement, CMOS Battery: paso 6, imagen 1 de 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, CMOS Battery: paso 6, imagen 2 de 3 HP EliteBook x360 830 G6 CMOS Battery Replacement, CMOS Battery: paso 6, imagen 3 de 3
    • Use your fingers or the pointed end of a spudger disconnect the CMOS battery connector.
  7. HP EliteBook x360 830 G6 CMOS Battery Replacement: paso 7, imagen 1 de 1
    • Remove the CMOS battery from its housing by pulling up the small, black plastic tab that is holding it in place.
Conclusión
Brody Reder
Miembro Desde 04/02/24
301 Reputación
3 Guías creadas
Equipo
IUPUI, Team 3-3, Harley Spring 2024 Miembro de IUPUI, Team 3-3, Harley Spring 2024
IUPUI-HARLEY-S24S3G3
Miembros de 4
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 46
Ultimos 30 días: 179
Todo El Tiempo: 1,422
