HP EliteBook 1040 G4 Battery Replacement
Introducción
Ir al paso 1Use this guide to replace the battery on the HP Elitebook 1040 G4. The battery is essential for providing power to the laptop. A faulty battery can cause many adverse effects on your laptop experience: from overheating to computer crashes, or even just simple difficulties with charging or holding a charge. Although the battery in this computer is rechargeable, the battery itself may need to be replaced after long and repeated use.
To complete this guide, you will need a T5 Torx head screwdriver and a Phillips #00 screwdriver.
Before beginning, be sure to unplug and completely power off your computer.
Qué necesitas
Kits de reparación
Este kit contiene todas las piezas y herramientas necesarias para completar esta guía.
Partes
Herramientas
Ver más…
Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Una persona más ha completado esta guía.
