Saltar al contenido principal
HP Compaq nc8430 RAM Replacement
bryan ingram
bryan ingram y 5 otros contribuidores
Última actualización: June 17, 2019
1 - 4 minutos
Fácil
Faltan Detalles
Introducción
Ir al paso 1
This guide will show you how to remove the RAM from a HP Compaq nc8430.
Qué necesitas
  1. HP Compaq nc8430 RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Completely shut down the device and unplug any adapters and cords connected to the device.
    • Carefully flip the device over so that the bottom is facing up.
    • Slide both of the latches to the left.
  2. HP Compaq nc8430 RAM Replacement: paso 2, imagen 1 de 1
    • Slide up against the three lines the battery has.
  3. HP Compaq nc8430 RAM Replacement: paso 3, imagen 1 de 1
    • Slide the battery up and away from the laptop.
    • Slowly remove the battery to prevent any connectors from getting damaged.
  4. HP Compaq nc8430 RAM Replacement, Remove RAM cover: paso 4, imagen 1 de 1
    • Completely shut down the device and unplug any adapters and chords that are connected.
  5. HP Compaq nc8430 RAM Replacement: paso 5, imagen 1 de 1
    • Use a screwdriver to remove the single screw on the covering located on the back of the laptop.
  6. HP Compaq nc8430 RAM Replacement, Locate RAM: paso 6, imagen 1 de 1
    • Locate the RAM after you remove the covering.
  7. HP Compaq nc8430 RAM Replacement, Push clamps aside: paso 7, imagen 1 de 1
    • Use fingers or tools to press the clamps that hold the RAM in to the side.
  8. HP Compaq nc8430 RAM Replacement, Pull RAM up to remove: paso 8, imagen 1 de 1
    • Place your fingers firmly on the RAM and pull it up.
  9. HP Compaq nc8430 RAM Replacement, Remove RAM: paso 9, imagen 1 de 1
    • Place fingers firmly on RAM and pull it to remove it.
Conclusión
bryan ingram
Miembro Desde 03/27/17
101 Reputación
1 Guía escrita
Equipo
Un comentario
umm fine, except there is another module under the keyboard , rather an important fact to be overlooking
bari - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 768
