Saltar al contenido principal
HP Chromebook 14-ca061dx Keyboard Replacement
Jean Arevalo
Jean Arevalo y 7 otros contribuidores
Última actualización: March 3, 2025
10 - 20 minutos
Fácil
Mejor introducción
Estudiante en Progreso
Introducción
Ir al paso 1
This guide contains step-by-step instructions for replacing the keyboard and surrounding area on an HP Chromebook 14-ca061dx. Before repairing any internal piece, you must first remove the keyboard.
To complete this guide, you will need the opening tool, the Phillips 64-bit screwdriver with the PH0 head, and a spudger.
Whether your trackpad is malfunctioning or you need to repair an internal component, following these directions will help you complete the replacement process safely and effectively!
Qué necesitas
Herramientas
Ver más…
  1. HP Chromebook 14-ca061dx Keyboard Replacement, Keyboard: paso 1, imagen 1 de 3 HP Chromebook 14-ca061dx Keyboard Replacement, Keyboard: paso 1, imagen 2 de 3 HP Chromebook 14-ca061dx Keyboard Replacement, Keyboard: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    $3.99
    • Flip the Chromebook to the underside with the hinge at the top.
    • Remove the seven, small rubber stoppers using angled tweezers.
  2. HP Chromebook 14-ca061dx Keyboard Replacement: paso 2, imagen 1 de 3 HP Chromebook 14-ca061dx Keyboard Replacement: paso 2, imagen 2 de 3 HP Chromebook 14-ca061dx Keyboard Replacement: paso 2, imagen 3 de 3
    • Remove the two bigger rubber stoppers using a metal spudger.
  3. HP Chromebook 14-ca061dx Keyboard Replacement: paso 3, imagen 1 de 2 HP Chromebook 14-ca061dx Keyboard Replacement: paso 3, imagen 2 de 2
    • Remove the seven 6mm Phillips #00 screws found underneath the stoppers.
  4. HP Chromebook 14-ca061dx Keyboard Replacement: paso 4, imagen 1 de 2 HP Chromebook 14-ca061dx Keyboard Replacement: paso 4, imagen 2 de 2
    • Remove the two 9mm Phillips #1 screws.
  5. HP Chromebook 14-ca061dx Keyboard Replacement: paso 5, imagen 1 de 3 HP Chromebook 14-ca061dx Keyboard Replacement: paso 5, imagen 2 de 3 HP Chromebook 14-ca061dx Keyboard Replacement: paso 5, imagen 3 de 3
    • Flip the Chromebook over and open the cover.
    • Insert the iFixit opening tool into the edge of the keyboard, near the mouse pad.
    • By lifting the tool at an angle, work the tool around the entire perimeter of the keyboard.
    • You will hear a popping noise when you disconnect the keyboard.
  6. HP Chromebook 14-ca061dx Keyboard Replacement: paso 6, imagen 1 de 3 HP Chromebook 14-ca061dx Keyboard Replacement: paso 6, imagen 2 de 3 HP Chromebook 14-ca061dx Keyboard Replacement: paso 6, imagen 3 de 3
    • Lift the keyboard from the mouse pad.
    • Lift the keyboard carefully, because there are cables connecting the keyboard to the base and they may break.
    • Use your finger or the spudger tool to flip up the black locking flap.
    • Grab the black cable and pull away from the motherboard.
    • Carefully lift the black piece up, because it is fragile and can break easily.
  7. HP Chromebook 14-ca061dx Keyboard Replacement: paso 7, imagen 1 de 3 HP Chromebook 14-ca061dx Keyboard Replacement: paso 7, imagen 2 de 3 HP Chromebook 14-ca061dx Keyboard Replacement: paso 7, imagen 3 de 3
    • Flip up the white locking flap with your finger or spudger tool.
    • Remove the white cable from the motherboard.
    • Carefully lift the white piece up, because it is fragile and can break easily.
  8. HP Chromebook 14-ca061dx Keyboard Replacement: paso 8, imagen 1 de 1
    • Lift the rest of the keyboard up from the base of the Chromebook.
Conclusión
Jean Arevalo
Miembro Desde 10/31/19
778 Reputación
6 Guías creadas
Equipo
Un comentario
good afternoon, excuse me, I have a question, I also have the same brand HP Chromebook 14-ca061dx and I just want to know where the anti-write screw is, I want to remove the anti-write screw to install windows 10..
Marcos Perea - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 1,454
