Saltar al contenido principal
HP Chromebook 11A G8 EE Keyboard Assembly Replacement
Ella Portwood
Ella Portwood y 4 otros contribuidores
Última actualización: September 15, 2023
10 - 15 minutos
Moderado
Introducción
Ir al paso 1
If you need to replace the keyboard assembly of your HP Chromebook 11A G8 EE, follow this guide. The keyboard assembly could become damaged if liquid is spilled on the laptop, if multiple keys are broken, or if the keyboard becomes unresponsive and you've confirmed that you've made all of the appropriate updates to drivers, etc.
In addition, this is a prerequisite for other repairs on the HP Chromebook 11A G8 EE. By following this guide, you will have access to the internals of the device including the battery, motherboard, speakers, and trackpad.
Before beginning, make sure you power off and disconnect your Chromebook from any external power source.
Qué necesitas
Herramientas
Ver más…
  1. HP Chromebook 11A G8 EE Keyboard Assembly Replacement, Keyboard Assembly: paso 1, imagen 1 de 2 HP Chromebook 11A G8 EE Keyboard Assembly Replacement, Keyboard Assembly: paso 1, imagen 2 de 2
    • On the bottom of the laptop, remove four 7 mm screw using a Phillips #1 screwdriver.
    • Using the Phillips #1 screwdriver, remove the two remaining 8 mm screws by the hinges.
  2. HP Chromebook 11A G8 EE Keyboard Assembly Replacement: paso 2, imagen 1 de 3 HP Chromebook 11A G8 EE Keyboard Assembly Replacement: paso 2, imagen 2 de 3 HP Chromebook 11A G8 EE Keyboard Assembly Replacement: paso 2, imagen 3 de 3
    • Flip the laptop over and open up the display.
    • Using the iFixit opening tool, carefully separate the palm rest from the bottom cover by working your way around the perimeter and prying it up.
    • You will hear an audible and tactile click or pop letting you know that you have unclipped a portion of the palm rest from the base enclosure.
    • Lift the palm rest of the laptops towards you, away from the screen.
  3. HP Chromebook 11A G8 EE Keyboard Assembly Replacement: paso 3, imagen 1 de 2 HP Chromebook 11A G8 EE Keyboard Assembly Replacement: paso 3, imagen 2 de 2
    • Carefully, lift the keyboard ribbon lock and disconnect the keyboard ribbon from the motherboard.
    • Disconnect the touchpad ribbon from the motherboard, and remove top cover.
    • Remove the keyboard.
Conclusión
6 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 18
Todo El Tiempo: 2,691
