Saltar al contenido principal
HP 15-bw0xx Battery Replacement
Imani Kimbrough
Imani Kimbrough y 2 otros contribuidores
Última actualización: April 20, 2023
1 minuto
Muy fácil
Introducción
Ir al paso 1
If your HP 15-bw0xx laptop is unable to charge correctly or can't seem to hold power, consider following this guide to replace its battery. A bad battery is one of the top reasons for this problem and often happens gradually over time.
Be sure to unplug your laptop and turn it off before starting this guide.
  1. HP 15-bw0xx Battery Replacement, HP 15-bw0xx Battery: paso 1, imagen 1 de 3 HP 15-bw0xx Battery Replacement, HP 15-bw0xx Battery: paso 1, imagen 2 de 3 HP 15-bw0xx Battery Replacement, HP 15-bw0xx Battery: paso 1, imagen 3 de 3
    • First, start by identifying your laptop. Be sure it is specifically the "HP Laptop 15-bw0xx" model.
    • If you are unsure of the model, turn on your laptop. Then press and hold the "FN" key and the "ESC" key at the same time.
    • The model type is under the title "Product name."
  2. HP 15-bw0xx Battery Replacement: paso 2, imagen 1 de 1
    • Turn the closed laptop over onto its face, with the hinged side facing away from you.
    • Be sure to unplug your laptop and turn it off before continuing.
  3. HP 15-bw0xx Battery Replacement: paso 3, imagen 1 de 3 HP 15-bw0xx Battery Replacement: paso 3, imagen 2 de 3 HP 15-bw0xx Battery Replacement: paso 3, imagen 3 de 3
    • Place a finger on the top left slider, then push the black piece all the way to the right.
    • A finger grip to slide the hinge lock open lies to the left of a closed padlock symbol. This is how the battery is unlocked or locked in place.
  4. HP 15-bw0xx Battery Replacement: paso 4, imagen 1 de 3 HP 15-bw0xx Battery Replacement: paso 4, imagen 2 de 3 HP 15-bw0xx Battery Replacement: paso 4, imagen 3 de 3
    • Place a finger on the top right slider, then slide the black piece all the way to the left until it clicks out of place.
    • There will be three vertically parallel finger grips on the slider and a small 3/4 full battery symbol to the left of the slider. This slider is what detaches the battery from the laptop.
    • You may need to use a thumb or a little force to complete this step.
  5. HP 15-bw0xx Battery Replacement: paso 5, imagen 1 de 1
    • Remove the battery from the laptop.
  6. HP 15-bw0xx Battery Replacement: paso 6, imagen 1 de 3 HP 15-bw0xx Battery Replacement: paso 6, imagen 2 de 3 HP 15-bw0xx Battery Replacement: paso 6, imagen 3 de 3
    • Gently line the new battery up to the slot in which you removed the old battery from.
    • Press the battery into the slot until you hear it click into place.
  7. HP 15-bw0xx Battery Replacement: paso 7, imagen 1 de 3 HP 15-bw0xx Battery Replacement: paso 7, imagen 2 de 3 HP 15-bw0xx Battery Replacement: paso 7, imagen 3 de 3
    • Reverse Step #4 in order to safely lock the battery in place.
Conclusión
After completing all of these steps, you will have successfully replaced your HP Laptop 15-bw0xx battery.
3 personas más completaron esta guía.
Un comentario
hello, any idea where I can get a genuine battery for this laptop?
Brian Mwangi - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 30
Todo El Tiempo: 3,454
