Saltar al contenido principal
Esta guía ha sufrido modificaciones. Revisa la última versión sin revisar.
HP 14-dq0052dx Motherboard Replacement
DamianR
DamianR y otro contribuidor
Última actualización: January 2, 2025
15 - 40 minutos
Muy difícil
Introducción
Ir al paso 1
This guide will show you how to replace the motherboard in an HP 14-dq0052dx laptop. It could be the charging port that is broken, and with that the motherboard needs to be replaced since the charging port is soldered to it. If you know how to solder then the best course of action is to try to replace the charging port, but if you're not then replacing the motherboard is the best option after that. There will be some wires that need to be removed so be very careful with removing them or you might damage your laptop further.
Qué necesitas
Herramientas
Ver más…
  1. HP 14-dq0052dx Motherboard Replacement, Back Panel: paso 1, imagen 1 de 1
    • Orient your laptop so that the vents are facing upwards.
  2. HP 14-dq0052dx Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the rubber feet.
  3. HP 14-dq0052dx Motherboard Replacement: paso 3, imagen 1 de 2 HP 14-dq0052dx Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove the four M2.0 x 6 mm screws using a JIS #1 screwdriver.
    • Remove the two M2.5 x 6 mm screws using a JIS #1 screwdriver.
    • Remove the two M2.0 x 4 mm screws using a JIS #1 screwdriver.
    • Use an iFixit opening tool to pry the back cover away from the laptop.
  4. HP 14-dq0052dx Motherboard Replacement, Battery: paso 4, imagen 1 de 1
    • Unplug the battery from the motherboard.
    • Carefully pull back and raise the battery out of its slot.
    • Replace the battery.
  5. HP 14-dq0052dx Motherboard Replacement, Motherboard: paso 5, imagen 1 de 1
    • Remove the five 4 mm screws from the heatsink.
  6. HP 14-dq0052dx Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove the heatsink from the laptop.
  7. HP 14-dq0052dx Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the 4 mm screw from the bracket holding down the motherboard.
  8. HP 14-dq0052dx Motherboard Replacement: paso 8, imagen 1 de 2 HP 14-dq0052dx Motherboard Replacement: paso 8, imagen 2 de 2
    • Lift up the retaining clip to access the ribbon cable attached to the motherboard.
    • Be careful when removing the ribbon cable as it is prone to ripping which will damage it.
    • Remove the ribbon cable from the motherboard
  9. HP 14-dq0052dx Motherboard Replacement: paso 9, imagen 1 de 1
    • Lift up this tab and remove the ribbon cable from the motherboard.
    • Be gentle with the ribbon cable as it can easily tear.
  10. HP 14-dq0052dx Motherboard Replacement: paso 10, imagen 1 de 2 HP 14-dq0052dx Motherboard Replacement: paso 10, imagen 2 de 2
    • Remove the 4 mm screw from the Wi-Fi card.
    • Remove the Wi-Fi card from the motherboard.
  11. HP 14-dq0052dx Motherboard Replacement: paso 11, imagen 1 de 2 HP 14-dq0052dx Motherboard Replacement: paso 11, imagen 2 de 2
    • Disconnect the small wires from the top of the motherboard.
    • Be extremely careful with these wires as bending them can cause the fragile inner wire to break.
  12. HP 14-dq0052dx Motherboard Replacement: paso 12, imagen 1 de 1
    • Carefully remove the motherboard.
Conclusión
DamianR
Miembro Desde 10/18/24
279 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 2-5, Konn Fall 2024 Miembro de UMass Dartmouth, Team 2-5, Konn Fall 2024
UMASSD-KONN-F24S2G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 21
Todo El Tiempo: 97
