Saltar al contenido principal
HP 14-dq0052dx Battery Replacement
Jordan Graham
Jordan Graham y 3 otros contribuidores
Última actualización: January 2, 2025
5 minuto
Fácil
Introducción
Ir al paso 1
When diagnosing your HP 14-dq0052d laptop, one thing that may cause it to not power on is the battery. After trying different chargers and ports to see if that might be the cause, the next step is to change the battery. Make sure to de-static yourself by touching a grounding material like a piece of metal before working with the guts of the laptop as a zap from static electricity can cause another part to break and cause more problems for you to fix. These are the steps you need to take to replace the battery for your laptop.
Qué necesitas
Herramientas
  1. HP 14-dq0052dx Battery Replacement, Back Panel: paso 1, imagen 1 de 1
    • Orient your laptop so that the vents are facing upwards.
  2. HP 14-dq0052dx Battery Replacement: paso 2, imagen 1 de 1
    • Remove the rubber feet.
  3. HP 14-dq0052dx Battery Replacement: paso 3, imagen 1 de 2 HP 14-dq0052dx Battery Replacement: paso 3, imagen 2 de 2
    • Remove the four M2.0 x 6 mm screws using a JIS #1 screwdriver.
    • Remove the two M2.5 x 6 mm screws using a JIS #1 screwdriver.
    • Remove the two M2.0 x 4 mm screws using a JIS #1 screwdriver.
    • Use an iFixit opening tool to pry the back cover away from the laptop.
  4. HP 14-dq0052dx Battery Replacement, Battery: paso 4, imagen 1 de 1
    • Unplug the battery from the motherboard.
    • Carefully pull back and raise the battery out of its slot.
    • Replace the battery.
Conclusión
Jordan Graham
Miembro Desde 10/18/24
195 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 2-5, Konn Fall 2024 Miembro de UMass Dartmouth, Team 2-5, Konn Fall 2024
UMASSD-KONN-F24S2G5
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 75
