Saltar al contenido principal
GoPro Hero3+ Silver Edition Front Panel Replacement
Patrick Cook
Patrick Cook y 6 otros contribuidores
Última actualización: May 31, 2021
2 minuto
Muy fácil
Introducción
Ir al paso 1
Oops! You scratched the front of your GoPro and you don't want others to question if you take care of your camera. Let's replace that face plate and make it look good as new!
Qué necesitas
Partes
Herramientas
  1. GoPro Hero3+ Silver Edition Front Panel Replacement, Front Panel: paso 1, imagen 1 de 1
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
  2. GoPro Hero3+ Silver Edition Front Panel Replacement: paso 2, imagen 1 de 1
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
Conclusión
4 personas más completaron esta guía.
Patrick Cook
Miembro Desde 10/01/15
699 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 5-8, Maness Fall 2015 Miembro de Cal Poly, Team 5-8, Maness Fall 2015
CPSU-MANESS-F15S5G8
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 616
