Giant Iguana Mountain Bike Front Brake Cable Replacement
Introducción
Ir al paso 1Sometimes you may need to replace your bike brake cables when they become frayed, rigid, or no longer fit for use. This guide will show you how to replace the front brake cable of a Giant Iguana Mountain bike. You should exercise caution when using cable cutters, but otherwise, no special skills are needed or hazards to look out for. From the time you start the repair to the time you complete it, your front brake will be completely unusable. Ensure you have the time to finish before you need to ride again.
Qué necesitas
Partes
Herramientas
Ver más…
Using your hex screwdriver, loosen this bolt to release the clamp, allowing the brake cable to be removed from the caliper.
