Saltar al contenido principal
Fujifilm Finepix S1800 Top Cover Replacement
Ryan Rockford
Ryan Rockford y 6 otros contribuidores
Última actualización: January 5, 2024
25 - 30 minutos
Difícil
Necesita más imágenes
Introducción
Ir al paso 1
Is the flash not flipping up on your Fujifilm Finepix S1800 camera? It might be time to replace the top cover plate. This guide will show you how to replace the top cover.
Qué necesitas
Herramientas
Ver más…
  1. Fujifilm Finepix S1800 Top Cover Replacement, Back Cover Assembly: paso 1, imagen 1 de 1
    • Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
  2. Fujifilm Finepix S1800 Top Cover Replacement: paso 2, imagen 1 de 1
    • Unscrew the four 4mm screws on the right-hand side of the camera with the JIS #1 screwdriver.
  3. Fujifilm Finepix S1800 Top Cover Replacement: paso 3, imagen 1 de 1
    • Unscrew the three 4mm screws on the bottom of the camera with the JIS #1 screwdriver.
  4. Fujifilm Finepix S1800 Top Cover Replacement: paso 4, imagen 1 de 2 Fujifilm Finepix S1800 Top Cover Replacement: paso 4, imagen 2 de 2
    • Take the plastic opening tool and place it in the space between the top of the screen and the top of the camera.
    • The cover will pop out.
    • You may have to work the back cover from different sides to get it to pop off.
  5. Fujifilm Finepix S1800 Top Cover Replacement, LCD Screen: paso 5, imagen 1 de 2 Fujifilm Finepix S1800 Top Cover Replacement, LCD Screen: paso 5, imagen 2 de 2
    • Remove the three 2 mm screws from the back cover plate with the Phillips #000 screwdriver.
    • Gently lift the back cover away from the device.
    • Do not pull or yank free. The LCD screen is connected to the motherboard via a small ribbon cable.
  6. Fujifilm Finepix S1800 Top Cover Replacement: paso 6, imagen 1 de 1
    • Move the lever to disconnect the ribbon cable from the circuit board.
    • Do not rip the fragile micro ribbon cable.
  7. Fujifilm Finepix S1800 Top Cover Replacement: paso 7, imagen 1 de 1
    • Gently remove the LCD screen.
    • Do not touch the screen directly.
  8. Fujifilm Finepix S1800 Top Cover Replacement, Top Cover: paso 8, imagen 1 de 1
    • Lift the flash.
    • Remove the two 4 mm screws from the top of the camera with the JIS #1 screwdriver.
  9. Fujifilm Finepix S1800 Top Cover Replacement: paso 9, imagen 1 de 2 Fujifilm Finepix S1800 Top Cover Replacement: paso 9, imagen 2 de 2
    • Remove the 4 mm screws from the left and right sides of the camera with the JIS #1 screwdriver.
  10. Fujifilm Finepix S1800 Top Cover Replacement: paso 10, imagen 1 de 2 Fujifilm Finepix S1800 Top Cover Replacement: paso 10, imagen 2 de 2
    • Switch the lever to disconnect the micro strip that connects the top plate.
    • Do not rip the micro strip.
  11. Fujifilm Finepix S1800 Top Cover Replacement: paso 11, imagen 1 de 1
    • Remove the top cover.
Conclusión
Una persona más ha completado esta guía.
Ryan Rockford
Miembro Desde 02/15/17
618 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 8-6, Eyestone Spring 2017 Miembro de USF Tampa, Team 8-6, Eyestone Spring 2017
USFT-EYESTONE-S17S8G6
Miembros de 4
10 Guías creadas
Un comentario
I had a problem with my Fuji Fine pix S 2950 (similar case) On / Off switch, this guide was invaluable to help me get into the top case moulding.
The fault was a crack around a solder pad were the SMT switch is mounted on the PCB , a simple solder job but an absolute bugger to get to.
Thank you for this simple and straight forward guide.
Bob Wilkins - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 16
Todo El Tiempo: 709
