Fujifilm FinePix XP80 Speaker Replacement
Introducción
Ir al paso 1Learn how to replace the speaker in a Fujifilm FinePix XP80 camera.
Please note: this guide requires soldering. For more information, see the Soldering Guide.
Qué necesitas
Open the side panel which houses the battery compartment. Press the center button down and twist the dial.
Using a Phillips PH000 bit, remove the five 2mm screws on the bottom of the camera.
Using the H1.3 hex head bit, remove the four screws on the front of the camera.
Using a PH000 Phillips bit, remove the screw shown.
Unclip the three ribbon cables that are still attached to the motherboard.
Use the plastic opening tool to gently pry the motherboard loose.
Move the motherboard aside slightly to reveal the speaker, which is connected to the motherboard by red and black wires.
