Saltar al contenido principal
Flash and re-install the firmware of TCA Yoke
Formica Fusca
Formica Fusca y otro contribuidor
Última actualización: November 8, 2024
2 - 5 minutos
Muy fácil
Guía aportada por comunidad
Introducción
Ir al paso 1
Guide on how to re-install the firmware, if it became corrupted and the TCA Yoke is not powering on.
    • Download and install the driver package from here.
    • TCA Yoke and TCA Quadrant both use the same driver.
    • Press on the Windows button and type "Firmware Update" into the search.
    • Unplug your TCA Yoke from USB port if you already have it plugged-in
  1. Flash and re-install the firmware of TCA Yoke, Press and hold the XBOX button: paso 4, imagen 1 de 1
    • Press and hold the Xbox button.
    • Make sure to set your Yoke into PC mode, using the switch at the back, before proceeding to the next step.
  2. Flash and re-install the firmware of TCA Yoke, Connect to USB while holding the Xbox button: paso 5, imagen 1 de 1
    • Keep holding the Xbox button and connect the Yoke to USB port.
    • Once connected, wait a few seconds and let go of the button.
    • Your TCA Yoke should show up in Firmware Updater.
    • Press OK on the Firmware Updater and wait for update to complete.
Linea de Meta
Formica Fusca
Miembro Desde 08/01/24
2,587 Reputación
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 100
