Saltar al contenido principal
Fender 68 Custom Deluxe Reverb Speaker Replacement
CrimsonSkyeHochhalter
CrimsonSkyeHochhalter y 2 otros contribuidores
Última actualización: January 17, 2025
15 - 45 minutos
Moderado
Introducción
Ir al paso 1
Replacing a speaker in a tube amp is a straightforward process that most people can accomplish relatively easily at home.
If your amplifier is malfunctioning, you might need to replace the speaker.
A functional speaker provides optimal sound, which is essential to the proper functioning of the amplifier. If you notice that your speaker sounds damaged, consider troubleshooting the other parts of the amplifier to confirm that the speaker is the problem.
A damaged speaker can cause damage to connected parts. If your speaker is overheating, shorting, or water-damaged, do not attempt to power on and take appropriate precautions.
Make sure to disconnect your device from power before you begin.
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Fender 68 Custom Deluxe Reverb Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Lay the amplifier face-down.
  2. Fender 68 Custom Deluxe Reverb Speaker Replacement: paso 2, imagen 1 de 1
    • Remove both back plates by unscrewing eight 1.2 mm screws with a Phillips #1 screwdriver.
    • Keep track of the eyelets.
  3. Fender 68 Custom Deluxe Reverb Speaker Replacement: paso 3, imagen 1 de 2 Fender 68 Custom Deluxe Reverb Speaker Replacement: paso 3, imagen 2 de 2
    • Remove the power stage vacuum tubes. Gently pull out the tube while simultaneously pressing down the metal holder.
  4. Fender 68 Custom Deluxe Reverb Speaker Replacement: paso 4, imagen 1 de 3 Fender 68 Custom Deluxe Reverb Speaker Replacement: paso 4, imagen 2 de 3 Fender 68 Custom Deluxe Reverb Speaker Replacement: paso 4, imagen 3 de 3
    • Remove the positive and negative speaker connections and label them accordingly with a marker and painter's tape.
  5. Fender 68 Custom Deluxe Reverb Speaker Replacement: paso 5, imagen 1 de 1
    • Remove the other side of the speaker connection from the internal speaker input jack.
  6. Fender 68 Custom Deluxe Reverb Speaker Replacement: paso 6, imagen 1 de 3 Fender 68 Custom Deluxe Reverb Speaker Replacement: paso 6, imagen 2 de 3 Fender 68 Custom Deluxe Reverb Speaker Replacement: paso 6, imagen 3 de 3
    • Remove the reverb tank by unscrewing two 1.2 mm screws with a Phillips #1 screwdriver and unfastening the velcro by hand.
    • The wire must stay connected.
  7. Fender 68 Custom Deluxe Reverb Speaker Replacement: paso 7, imagen 1 de 3 Fender 68 Custom Deluxe Reverb Speaker Replacement: paso 7, imagen 2 de 3 Fender 68 Custom Deluxe Reverb Speaker Replacement: paso 7, imagen 3 de 3
    • Remove the speaker by unscrewing four 1.2 mm screws with a Phillips #1 screwdriver.
    • Potential for device damage: Do not touch the front of the speaker when handling.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 95
