Saltar al contenido principal
Epson VS250 Lamp Replacement
Warren Cutlip
Warren Cutlip y 4 otros contribuidores
Última actualización: December 28, 2021
10 - 20 minutos
Fácil
Necesita mejores imágenes
Introducción
Ir al paso 1
If your Epson VS250 projector is having image display issues then this might be the right guide for you. The lamp is essentially the most important component in the projector and without it you wouldn’t be able to display images onto a screen. The Epson VS250 projector has a status light for the lamp and this is useful for indicating that a problem has occurred. It can even warn you if the lamp needs to be replaced ahead of time. This guide will help assist you in replacing the lamp.
Qué necesitas
Herramientas
  1. Epson VS250 Lamp Replacement, Lamp: paso 1, imagen 1 de 1
    • Place the projector on a flat surface.
    • Orient the projector so that the the word "Epson" is facing you.
    • Use Phillips #1 screwdriver to loosen the 10 mm screw on the top right corner of the projector.
    • The screw does not need to come all the way out.
  2. Epson VS250 Lamp Replacement: paso 2, imagen 1 de 1
    • Slide the cover to the right and lift the cover up and out to remove.
  3. Epson VS250 Lamp Replacement: paso 3, imagen 1 de 1
    • Use a Phillips #1 screwdriver to loosen the two 10 mm screws that hold the lamp in place.
    • The two 10 mm screws do not need to come all the way out. Just ensure they are loose.
  4. Epson VS250 Lamp Replacement: paso 4, imagen 1 de 2 Epson VS250 Lamp Replacement: paso 4, imagen 2 de 2
    • After loosening both screws, remove the lamp from the projector by pulling it up and out.
Conclusión
Una persona más ha completado esta guía.
Warren Cutlip
Miembro Desde 09/28/21
604 Reputación
5 Guías creadas
Equipo
Clemson, Team 4-2, Hunter Fall 2021 Miembro de Clemson, Team 4-2, Hunter Fall 2021
CLEM-HUNTER-F21S4G2
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 592
