Saltar al contenido principal
Dreamax DMX-ST7A Battery Replacement
Stacey Mattila
Stacey Mattila y otro contribuidor
Última actualización: December 28, 2018
15 - 30 minutos
Moderado
Introducción
Ir al paso 1
We will show how to replace the tablet's battery.
Qué necesitas
Herramientas
Ver más…
  1. Dreamax DMX-ST7A Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Position the tablet so the ports and screws are facing you.
  2. Dreamax DMX-ST7A Battery Replacement: paso 2, imagen 1 de 1
    • Remove the two 2.5mm screws using the Phillips #00 precision screwdriver.
  3. Dreamax DMX-ST7A Battery Replacement: paso 3, imagen 1 de 2 Dreamax DMX-ST7A Battery Replacement: paso 3, imagen 2 de 2
    • Use the plastic opening tool to assist in removing the back cover.
  4. Dreamax DMX-ST7A Battery Replacement: paso 4, imagen 1 de 1
    • Upon removing the back cover position the tablet as seen in the picture.
  5. Dreamax DMX-ST7A Battery Replacement, Battery: paso 5, imagen 1 de 2 Dreamax DMX-ST7A Battery Replacement, Battery: paso 5, imagen 2 de 2
    • Remove any tape that might be holding the wires in place.
  6. Dreamax DMX-ST7A Battery Replacement: paso 6, imagen 1 de 3 Dreamax DMX-ST7A Battery Replacement: paso 6, imagen 2 de 3 Dreamax DMX-ST7A Battery Replacement: paso 6, imagen 3 de 3
    • Remove the black and gold tab connecting the battery to the tablet's frame.
  7. Dreamax DMX-ST7A Battery Replacement: paso 7, imagen 1 de 1
    • Remove the the one red and two black wires that connect the battery to the motherboard.
  8. Dreamax DMX-ST7A Battery Replacement: paso 8, imagen 1 de 2 Dreamax DMX-ST7A Battery Replacement: paso 8, imagen 2 de 2
    • Remove the battery from the tablet.
  9. Dreamax DMX-ST7A Battery Replacement: paso 9, imagen 1 de 3 Dreamax DMX-ST7A Battery Replacement: paso 9, imagen 2 de 3 Dreamax DMX-ST7A Battery Replacement: paso 9, imagen 3 de 3
    • Install the new battery by soldering the three wires to the motherboard. For additional soldering instructions please view this page: Cómo soldar y desoldar conexiones
Conclusión
Stacey Mattila
Miembro Desde 03/18/15
543 Reputación
5 Guías creadas
Equipo
Michigan Tech, Team 1-4, Lauer Spring 2015 Miembro de Michigan Tech, Team 1-4, Lauer Spring 2015
MTU-LAUER-S15S1G4
2 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 452
