Saltar al contenido principal
Disassembling Nokia 3100b Speaker
Sterling Fuentes
Sterling Fuentes y 2 otros contribuidores
Última actualización: January 28, 2014
Sin estimación
Moderado
Fotos de acción
Estudiante en Progreso
Pasos faltantes
Bordeador de Pasos
Introducción
Ir al paso 1
This guide shows you how to access the speaker of your phone, the component which produces sound.
Qué necesitas
  1. Disassembling Nokia 3100b Speaker, Battery: paso 1, imagen 1 de 1
    • Make sure your phone is turned off.
  2. Disassembling Nokia 3100b Speaker: paso 2, imagen 1 de 1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Disassembling Nokia 3100b Speaker, SIM Card: paso 3, imagen 1 de 1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
  4. Disassembling Nokia 3100b Speaker: paso 4, imagen 1 de 1
    • Retrieve your SIM card.
  5. Disassembling Nokia 3100b Speaker, Screen: paso 5, imagen 1 de 1
    • Separate the front cover from the main body of the phone.
  6. Disassembling Nokia 3100b Speaker: paso 6, imagen 1 de 1
    • Remove the six screws along the edges of the phone.
  7. Disassembling Nokia 3100b Speaker: paso 7, imagen 1 de 1
    • Pull the screen assembly from the base of the phone.
  8. Disassembling Nokia 3100b Speaker: paso 8, imagen 1 de 1
    • Carefully lift the keypad portion of the screen assembly from the circuit board.
  9. Disassembling Nokia 3100b Speaker: paso 9, imagen 1 de 1
    • Separate the screen from the circuit board.
    • Reconnect the ports during reassembly or the screen will not function properly.
    • Remember to reconnect the screen to the circuit board when reassembling!
  10. Disassembling Nokia 3100b Speaker: paso 10, imagen 1 de 1
    • Gently push down on the screen to pop it off of the assembly.
  11. Disassembling Nokia 3100b Speaker: paso 11, imagen 1 de 1
    • When the screen falls out the assembly, two white tabs will fall out with it.
    • When reinstalling the screen, insert the tabs with the slanted side pointing upwards so they slide into the assembly.
  12. Disassembling Nokia 3100b Speaker, Speaker: paso 12, imagen 1 de 1
    • Set the screen and the tabs aside.
  13. Disassembling Nokia 3100b Speaker: paso 13, imagen 1 de 1
    • You can now access the speaker.
    • Note the tab on the end of the speaker. It must be placed in correctly in order to reinstall the speaker.
  14. Disassembling Nokia 3100b Speaker: paso 14, imagen 1 de 1
    • Remove the speaker from the assembly.
Conclusión
Equipo
Cal Poly, Team 29-64, Johann Spring 2010 Miembro de Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
Miembros de 3
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,221
