Introducción
The logic board is the brains behind the camera and should be handled delicately.
Herramientas
Partes
No se especificaron partes.
Remove the 2 screws (2.41 mm long) on the side of the camera next to the LCD screen.
Remove the 2 screws (4.08 mm) on the other side. One is located under the rubber USB flap.
Remove the last screw (2.59 mm) located on the bottom of the camera.
Slowly pull the back cover of the camera.
Remove the screw (2.59 mm) from the bottom of the camera.
Remove the screw (4.08 mm) from the menu button side of the camera.
Note: the 2 screws on the other side of the camera were already removed when taking off the back cover.
Unplug the green and white plugs connecting the top panel to the top of the logic board.
Dislodge the tab above the lens.
Dislodge the back tab.
Remove 2 screws(1.75mm) using a screwdriver.
Detach 3 ribbons by pulling up on them. All are on the front of the camera.
