Saltar al contenido principal
Disassembling Arnova 7K G3 Logic Board Ribbon Connectors
Kue
Kue y 5 otros contribuidores
Última actualización: May 7, 2024
10 - 15 minutos
Moderado
Fotos de acción
Bordeador de Pasos
Introducción
Ir al paso 1
A device's logic board has many electrical connections to other components within the device. This guide, using the Arnova 7K G3 Rear Cover Removal guide as a prerequisite, shows how to remove the ribbon connections from the logic board, which may help in determining a bad ribbon connector or other faulty wiring.
Qué necesitas
Herramientas
Ver más…
  1. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Rear Cover: paso 1, imagen 1 de 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Rear Cover: paso 1, imagen 2 de 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Rear Cover: paso 1, imagen 3 de 3
    • Remove four 5 mm Phillips #00 screws from each corner of the tablet.
  2. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: paso 2, imagen 1 de 2 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: paso 2, imagen 2 de 2
    • Place the iFixit opening tool in the notches between the cases and pull the covers apart.
  3. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: paso 3, imagen 1 de 1
    • Repeat step two until 3/4 of the rear cover is unlatched.
    • Proceed to remove the rear cover by gently pulling it apart by hand.
  4. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: paso 4, imagen 1 de 2 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Peel the copper tape covering the ribbon connector with a set of tweezers.
  5. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: paso 5, imagen 1 de 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: paso 5, imagen 2 de 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: paso 5, imagen 3 de 3
    • Locate the two gray pins on the ribbon connector.
    • Grab the first pin with tweezers and gently pull it towards the ribbon. Repeat the step.
    • Gently pull the ribbon cable out of the connection port.
  6. Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: paso 6, imagen 1 de 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: paso 6, imagen 2 de 3 Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: paso 6, imagen 3 de 3
    • Locate the ribbon connector two.
    • Locate the pins of ribbon connector two. Repeat step two for unlocking the pins.
    • Gently pull the ribbon out of the connection port.
Conclusión
Kue
Miembro Desde 03/18/15
301 Reputación
3 Guías creadas
Equipo
Michigan Tech, Team 1-2, Lauer Spring 2015 Miembro de Michigan Tech, Team 1-2, Lauer Spring 2015
MTU-LAUER-S15S1G2
Miembros de 2
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 8
Todo El Tiempo: 349
