Saltar al contenido principal
Dell XPS 15 L521X WiFi Card Replacement
SHELDON SANTOS
SHELDON SANTOS y otro contribuidor
Última actualización: June 6, 2018
3 minuto
Moderado
Introducción
Ir al paso 1
This guide will help you replace the Wifi card on your Dell XPS. The Wifi card is known to fail in the Dell XPS, so this easy repair should fix that. This guide will only require you to remove one screw, and pull the Wifi Card out of place.
Qué necesitas
Herramientas
  1. Dell XPS 15 L521X WiFi Card Replacement, Back Panel: paso 1, imagen 1 de 1
    • Find and remove the two .3cm torx head screws using a T5 screwdriver.
    • Find and remove the six Phillips head .3cm screws using a Phillips #0 screwdriver.
  2. Dell XPS 15 L521X WiFi Card Replacement: paso 2, imagen 1 de 1
    • Unplug the battery indicator.
  3. Dell XPS 15 L521X WiFi Card Replacement, WiFi Card: paso 3, imagen 1 de 1
    • Find the .3cm Phillips head screw holding the WiFi Card in place and remove it.
  4. Dell XPS 15 L521X WiFi Card Replacement: paso 4, imagen 1 de 1
    • Gently pull the WiFi card out of its place.
  5. Dell XPS 15 L521X WiFi Card Replacement: paso 5, imagen 1 de 1
    • Gently tug on the two wires connected to the Wifi card
Conclusión
SHELDON SANTOS
Miembro Desde 03/19/18
614 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 686
