Saltar al contenido principal
Dell XPS 15 9570 RAM Replacement
Hunter Kohlsmith
Hunter Kohlsmith y otro contribuidor
Última actualización: August 6, 2023
3 minuto
Fácil
Introducción
Ir al paso 1
This guide will show you how to replace the RAM in a Dell XPS 15 9570 laptop. RAM allows applications and processes to store short-term memory and helps to optimize your computer's performance. This step-by-step guide will show you how to replace the RAM in a very easy manner. Be safe with your computer and happy fixing!
Qué necesitas
Herramientas
  1. Dell XPS 15 9570 RAM Replacement, Base Cover: paso 1, imagen 1 de 1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 RAM Replacement: paso 2, imagen 1 de 3 Dell XPS 15 9570 RAM Replacement: paso 2, imagen 2 de 3 Dell XPS 15 9570 RAM Replacement: paso 2, imagen 3 de 3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 RAM Replacement: paso 3, imagen 1 de 2 Dell XPS 15 9570 RAM Replacement: paso 3, imagen 2 de 2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 RAM Replacement: paso 4, imagen 1 de 1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 RAM Replacement, RAM: paso 5, imagen 1 de 2 Dell XPS 15 9570 RAM Replacement, RAM: paso 5, imagen 2 de 2
    • Use your fingers to pinch down the metal tabs holding the RAM in place. Do this for each tab.
  6. Dell XPS 15 9570 RAM Replacement: paso 6, imagen 1 de 1
    • Use your hands to carefully lift the RAM up and away from the tabs to safely take it out.
Conclusión
Una persona más ha completado esta guía.
Un comentario
Does the battery connector need to be detached?
Rori Monni - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 40
Todo El Tiempo: 1,081
