Saltar al contenido principal
Dell XPS 15 9530 Screen Replacement
Larissa Omura
Larissa Omura y 2 otros contribuidores
Última actualización: September 23, 2021
25 - 30 minutos
Moderado
Introducción
Ir al paso 1
Removal of the screen will be covered in this guide. To successfully remove the battery, a #0 Phillips screwdriver, a T5 Torx screwdriver, tweezers, and a plastic spudger are needed. Be careful disconnecting cables as to not break them or their connectors.
Qué necesitas
Herramientas
Ver más…
  1. Dell XPS 15 9530 Screen Replacement, Base Cover: paso 1, imagen 1 de 3 Dell XPS 15 9530 Screen Replacement, Base Cover: paso 1, imagen 2 de 3 Dell XPS 15 9530 Screen Replacement, Base Cover: paso 1, imagen 3 de 3
    • Using a T5 Torx screwdriver, remove ten 3mm screws.
  2. Dell XPS 15 9530 Screen Replacement: paso 2, imagen 1 de 2 Dell XPS 15 9530 Screen Replacement: paso 2, imagen 2 de 2
    • Lift the plastic tab.
    • Remove two 3mm Phillips #0 screws under the plastic tab.
  3. Dell XPS 15 9530 Screen Replacement: paso 3, imagen 1 de 1
    • Lift the lower case off.
  4. Dell XPS 15 9530 Screen Replacement, Battery: paso 4, imagen 1 de 2 Dell XPS 15 9530 Screen Replacement, Battery: paso 4, imagen 2 de 2
    • Using a Phillips #0 screwdriver, remove the seven 3.5mm screws that secure the battery to the palm rest assembly.
  5. Dell XPS 15 9530 Screen Replacement: paso 5, imagen 1 de 1
    • Disconnect the battery cable from the system board.
    • Be sure to use a plastic tool, not a metal one.
  6. Dell XPS 15 9530 Screen Replacement: paso 6, imagen 1 de 1
    • Lift the battery off the chassis.
  7. Dell XPS 15 9530 Screen Replacement, SSD: paso 7, imagen 1 de 1
    • Pull lift tabs and remove the plastic that covers the hard drive to expose the hard drive.
  8. Dell XPS 15 9530 Screen Replacement: paso 8, imagen 1 de 2 Dell XPS 15 9530 Screen Replacement: paso 8, imagen 2 de 2
    • Using a Phillips #0 screwdriver, remove two 2.5mm screws that secure the SSD to the chassis.
  9. Dell XPS 15 9530 Screen Replacement: paso 9, imagen 1 de 1
    • Pull the SSD out parallel to the mainboard.
  10. Dell XPS 15 9530 Screen Replacement, Screen: paso 10, imagen 1 de 2 Dell XPS 15 9530 Screen Replacement, Screen: paso 10, imagen 2 de 2
    • Unplug the screen connector.
  11. Dell XPS 15 9530 Screen Replacement: paso 11, imagen 1 de 2 Dell XPS 15 9530 Screen Replacement: paso 11, imagen 2 de 2
    • Using a Phillips #0 screwdriver, remove the four 4mm screws holding in the screen hinges.
  12. Dell XPS 15 9530 Screen Replacement: paso 12, imagen 1 de 1
    • Pull chassis away from screen assembly.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 27
Todo El Tiempo: 1,658
