Saltar al contenido principal
Dell XPS 15 9530 Keyboard Replacement
Larissa Omura
Larissa Omura y 3 otros contribuidores
Última actualización: May 7, 2024
25 - 30 minutos
Moderado
Introducción
Ir al paso 1
Removal of the keyboard will be covered in this guide. To successfully remove the keyboard, a #0 Phillips screwdriver, a T5 Torx screwdriver, a plastic spudger, and tweezers are needed. Be careful disconnecting cables as to not break them or their connectors.
Qué necesitas
Herramientas
Ver más…
  1. Dell XPS 15 9530 Keyboard Replacement, Base Cover: paso 1, imagen 1 de 3 Dell XPS 15 9530 Keyboard Replacement, Base Cover: paso 1, imagen 2 de 3 Dell XPS 15 9530 Keyboard Replacement, Base Cover: paso 1, imagen 3 de 3
    • Using a T5 Torx screwdriver, remove ten 3mm screws.
  2. Dell XPS 15 9530 Keyboard Replacement: paso 2, imagen 1 de 2 Dell XPS 15 9530 Keyboard Replacement: paso 2, imagen 2 de 2
    • Lift the plastic tab.
    • Remove two 3mm Phillips #0 screws under the plastic tab.
  3. Dell XPS 15 9530 Keyboard Replacement: paso 3, imagen 1 de 1
    • Lift the lower case off.
  4. Dell XPS 15 9530 Keyboard Replacement, Battery: paso 4, imagen 1 de 2 Dell XPS 15 9530 Keyboard Replacement, Battery: paso 4, imagen 2 de 2
    • Using a Phillips #0 screwdriver, remove the seven 3.5mm screws that secure the battery to the palm rest assembly.
  5. Dell XPS 15 9530 Keyboard Replacement: paso 5, imagen 1 de 1
    • Disconnect the battery cable from the system board.
    • Be sure to use a plastic tool, not a metal one.
  6. Dell XPS 15 9530 Keyboard Replacement: paso 6, imagen 1 de 1
    • Lift the battery off the chassis.
  7. Dell XPS 15 9530 Keyboard Replacement, Keyboard: paso 7, imagen 1 de 3 Dell XPS 15 9530 Keyboard Replacement, Keyboard: paso 7, imagen 2 de 3 Dell XPS 15 9530 Keyboard Replacement, Keyboard: paso 7, imagen 3 de 3
    • Remove the three 3.5mm Phillips #0 screws mounting the motherboard.
  8. Dell XPS 15 9530 Keyboard Replacement: paso 8, imagen 1 de 3 Dell XPS 15 9530 Keyboard Replacement: paso 8, imagen 2 de 3 Dell XPS 15 9530 Keyboard Replacement: paso 8, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Disconnect ribbon cables above the touch pad using tweezers.
  9. Dell XPS 15 9530 Keyboard Replacement: paso 9, imagen 1 de 3 Dell XPS 15 9530 Keyboard Replacement: paso 9, imagen 2 de 3 Dell XPS 15 9530 Keyboard Replacement: paso 9, imagen 3 de 3
    • Lift and remove the motherboard from the chassis.
  10. Dell XPS 15 9530 Keyboard Replacement: paso 10, imagen 1 de 3 Dell XPS 15 9530 Keyboard Replacement: paso 10, imagen 2 de 3 Dell XPS 15 9530 Keyboard Replacement: paso 10, imagen 3 de 3
    • Remove the ten 3mm Phillips #0 screws on the perimeter of the keyboard assembly.
    • Remove the ten 2.5mm Phillips #0 screws underneath the plastic shielding of the keyboard.
Conclusión
Un comentario
Thank you for this guide! Is there any way to obtain replacement screws for the outer perimeter of the keyboard? I’ve recently disassembled my XPS 9530 and found one of the screws is very stripped, I managed to get it out but it really shouldn’t be put back in due to the state of the head.
I’m struggling to find replacements for the size quoted. Are they Phillips M2 3mm silver screws?
James White - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 31
Todo El Tiempo: 6,926
