Saltar al contenido principal
Dell Wyse Xn0m Fan Replacement
Daniel Hill
Daniel Hill y 2 otros contribuidores
Última actualización: January 6, 2020
20 minuto
Difícil
Introducción
Ir al paso 1
If your device feels sluggish/lagging performance-wise over time of use, you might need to change the fan. If these symptoms are followed by overheating easily, the fan being very loud or sounds weird (clicking, clunks, rotational friction), you should definitely do so.
For this teardown, you will need a PH1 Phillips screwdriver and Spudger.
Follow the steps listed to access the fan and then follow back in reverse order to reassemble the laptop one you have replaced the fan with a new one.
Qué necesitas
Herramientas
Ver más…
  1. Dell Wyse Xn0m Fan Replacement, Fan: paso 1, imagen 1 de 3 Dell Wyse Xn0m Fan Replacement, Fan: paso 1, imagen 2 de 3 Dell Wyse Xn0m Fan Replacement, Fan: paso 1, imagen 3 de 3
    • Use a spudger to unclip the keyboard from the main body by disengaging the clips lined around the top and sides of the keyboard.
    • Once lifted, push the white slider holding blue ribbon cable and put keyboard to the side.
  2. Dell Wyse Xn0m Fan Replacement: paso 2, imagen 1 de 1
    • With the spudger, remove sliders that are holding the purple ribbon cable.
    • Disconnect cable by the power button.
  3. Dell Wyse Xn0m Fan Replacement: paso 3, imagen 1 de 1
    • Remove the five 7mm Phillips #1 screws underneath the keyboard.
  4. Dell Wyse Xn0m Fan Replacement: paso 4, imagen 1 de 1
    • Close the laptop and flip it over.
    • Remove eight 7mm Phillips #1 screws along the edges of laptop.
    • Put these screws to the side (make sure to keep them apart from keyboard screws).
  5. Dell Wyse Xn0m Fan Replacement: paso 5, imagen 1 de 1
    • After removing the screws, flip the laptop back over and open the screen.
    • Lift the laptop's keyboard/mouse pad top with an opening tool.
  6. Dell Wyse Xn0m Fan Replacement: paso 6, imagen 1 de 2 Dell Wyse Xn0m Fan Replacement: paso 6, imagen 2 de 2
    • Unplug the cable connecting the fan to the motherboard.
    • Lift the tape holding down the cables over the fan.
    • Undo two 5mm Phillips #1 screws.
    • The top left screw is covered by the cables. Use a spudger to get it out of the way.
    • Lift the fan out of its slot.
Conclusión
The process is simple but tedious. Be patient, keep the screws organized, be gentle with the clips and you are good to go!
2 personas más completaron esta guía.
Un comentario
excelent work. thanks for share
Asimple Guy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 27
Ultimos 30 días: 37
Todo El Tiempo: 1,128
