Saltar al contenido principal
Dell Vostro V13 Sound Card Replacement
Patrick Swaney
Patrick Swaney y 3 otros contribuidores
Última actualización: July 1, 2019
9 - 15 minutos
Moderado
Introducción
Ir al paso 1
You can follow these steps to replace the sound card in your Dell Vostro V13. Be sure to power down, unplug and also back-up your laptop in order to prevent injury and loss of data.
Qué necesitas
Herramientas
  1. Dell Vostro V13 Sound Card Replacement, Back Cover: paso 1, imagen 1 de 3 Dell Vostro V13 Sound Card Replacement, Back Cover: paso 1, imagen 2 de 3 Dell Vostro V13 Sound Card Replacement, Back Cover: paso 1, imagen 3 de 3
    • Back up the memory to an external drive and power off the laptop before starting.
    • Flip the laptop over so the vents are facing you.
    • Remove the six 5.0 mm Phillips #1 screws using the magnetic driver.
    • Remove the two 5.0 mm Phillips #1 screws on the back side of the laptop.
  2. Dell Vostro V13 Sound Card Replacement: paso 2, imagen 1 de 3 Dell Vostro V13 Sound Card Replacement: paso 2, imagen 2 de 3 Dell Vostro V13 Sound Card Replacement: paso 2, imagen 3 de 3
    • Slide out the SD and MicroSD holders.
    • If you are having trouble sliding them out, use the plastic opening tool.
  3. Dell Vostro V13 Sound Card Replacement: paso 3, imagen 1 de 3 Dell Vostro V13 Sound Card Replacement: paso 3, imagen 2 de 3 Dell Vostro V13 Sound Card Replacement: paso 3, imagen 3 de 3
    • Slide the plastic opening tool around the perimeter of the laptop until the cover pops off.
    • Pull the back cover off.
  4. Dell Vostro V13 Sound Card Replacement: paso 4, imagen 1 de 2 Dell Vostro V13 Sound Card Replacement: paso 4, imagen 2 de 2
    • Remove the three black 3.9 mm Phillips #1 screws holding the battery in place.
  5. Dell Vostro V13 Sound Card Replacement: paso 5, imagen 1 de 3 Dell Vostro V13 Sound Card Replacement: paso 5, imagen 2 de 3 Dell Vostro V13 Sound Card Replacement: paso 5, imagen 3 de 3
    • Flip up the clip of the ribbon connector.
    • Pull the strip out to disconnect the battery.
  6. Dell Vostro V13 Sound Card Replacement: paso 6, imagen 1 de 2 Dell Vostro V13 Sound Card Replacement: paso 6, imagen 2 de 2
    • Remove the battery.
    • Removing the battery allows you to work safely.
  7. Dell Vostro V13 Sound Card Replacement, Sound Card: paso 7, imagen 1 de 2 Dell Vostro V13 Sound Card Replacement, Sound Card: paso 7, imagen 2 de 2
    • Remove the black 3.0 mm Phillips #1 screw.
    • Remove the two 5.1 mm silver Phillips #1 screws.
  8. Dell Vostro V13 Sound Card Replacement: paso 8, imagen 1 de 2 Dell Vostro V13 Sound Card Replacement: paso 8, imagen 2 de 2
    • Disconnect the white plug on the top left corner of the sound card.
  9. Dell Vostro V13 Sound Card Replacement: paso 9, imagen 1 de 2 Dell Vostro V13 Sound Card Replacement: paso 9, imagen 2 de 2
    • Use the plastic opening tool to flip the ribbon connector up.
  10. Dell Vostro V13 Sound Card Replacement: paso 10, imagen 1 de 2 Dell Vostro V13 Sound Card Replacement: paso 10, imagen 2 de 2
    • Pull the sound card out of the laptop.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 21
Ultimos 30 días: 36
Todo El Tiempo: 642
