Saltar al contenido principal
Dell Vostro V13 SIM Card Replacement
Amy Ledermann
Amy Ledermann y 2 otros contribuidores
Última actualización: July 1, 2019
10 - 15 minutos
Moderado
Introducción
Ir al paso 1
If your laptop is giving you an error that your SIM card is not detected, and you are unable to resolve the issue, it may be damaged and need replacing. If you follow this guide, it will detail how to replace the SIM card in order to get your laptop working again properly. Before you begin this guide, make sure your laptop is powered off, unplugged, and you have backed up the hard drive in order to prevent injury as well as data loss.
Qué necesitas
Herramientas
  1. Dell Vostro V13 SIM Card Replacement, Back Cover: paso 1, imagen 1 de 3 Dell Vostro V13 SIM Card Replacement, Back Cover: paso 1, imagen 2 de 3 Dell Vostro V13 SIM Card Replacement, Back Cover: paso 1, imagen 3 de 3
    • Back up the memory to an external drive and power off the laptop before starting.
    • Flip the laptop over so the vents are facing you.
    • Remove the six 5.0 mm Phillips #1 screws using the magnetic driver.
    • Remove the two 5.0 mm Phillips #1 screws on the back side of the laptop.
  2. Dell Vostro V13 SIM Card Replacement: paso 2, imagen 1 de 3 Dell Vostro V13 SIM Card Replacement: paso 2, imagen 2 de 3 Dell Vostro V13 SIM Card Replacement: paso 2, imagen 3 de 3
    • Slide out the SD and MicroSD holders.
    • If you are having trouble sliding them out, use the plastic opening tool.
  3. Dell Vostro V13 SIM Card Replacement: paso 3, imagen 1 de 3 Dell Vostro V13 SIM Card Replacement: paso 3, imagen 2 de 3 Dell Vostro V13 SIM Card Replacement: paso 3, imagen 3 de 3
    • Slide the plastic opening tool around the perimeter of the laptop until the cover pops off.
    • Pull the back cover off.
  4. Dell Vostro V13 SIM Card Replacement: paso 4, imagen 1 de 2 Dell Vostro V13 SIM Card Replacement: paso 4, imagen 2 de 2
    • Remove the three black 3.9 mm Phillips #1 screws holding the battery in place.
  5. Dell Vostro V13 SIM Card Replacement: paso 5, imagen 1 de 3 Dell Vostro V13 SIM Card Replacement: paso 5, imagen 2 de 3 Dell Vostro V13 SIM Card Replacement: paso 5, imagen 3 de 3
    • Flip up the clip of the ribbon connector.
    • Pull the strip out to disconnect the battery.
  6. Dell Vostro V13 SIM Card Replacement: paso 6, imagen 1 de 2 Dell Vostro V13 SIM Card Replacement: paso 6, imagen 2 de 2
    • Remove the battery.
    • Removing the battery allows you to work safely.
  7. Dell Vostro V13 SIM Card Replacement, SIM Card: paso 7, imagen 1 de 3 Dell Vostro V13 SIM Card Replacement, SIM Card: paso 7, imagen 2 de 3 Dell Vostro V13 SIM Card Replacement, SIM Card: paso 7, imagen 3 de 3
    • Remove the black 3.1 mm Phillips #1 screw.
  8. Dell Vostro V13 SIM Card Replacement: paso 8, imagen 1 de 3 Dell Vostro V13 SIM Card Replacement: paso 8, imagen 2 de 3 Dell Vostro V13 SIM Card Replacement: paso 8, imagen 3 de 3
    • Use the plastic opening tool to disconnect the ribbon connector.
  9. Dell Vostro V13 SIM Card Replacement: paso 9, imagen 1 de 2 Dell Vostro V13 SIM Card Replacement: paso 9, imagen 2 de 2
    • Remove the SIM card.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 23
Todo El Tiempo: 285
