Saltar al contenido principal
Dell Vostro 5510 Speakers Replacement
Simon
Simon y otro contribuidor
Última actualización: June 11, 2024
10 minuto
Fácil
Introducción
Ir al paso 1
This guide shows how to replace the speakers in the Dell Vostro 5510.
The speakers allow sound to be played out directly from the laptop. If the audio being played begins to crackle or no sound is played when the volume is turned up, the speakers should be replaced.
Qué necesitas
Herramientas
Ver más…
  1. Dell Vostro 5510 Speakers Replacement, Back Cover: paso 1, imagen 1 de 1
    • Power off your laptop before beginning disassembly.
    • Place the laptop so the bottom cover is facing upwards.
  2. Dell Vostro 5510 Speakers Replacement: paso 2, imagen 1 de 1
    • Remove the remaining (M2x4mm) screws with the screwdriver.
    • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
  3. Dell Vostro 5510 Speakers Replacement: paso 3, imagen 1 de 3 Dell Vostro 5510 Speakers Replacement: paso 3, imagen 2 de 3 Dell Vostro 5510 Speakers Replacement: paso 3, imagen 3 de 3
    • Pry open the top left corner of the cover with the opening tool.
    • Pry open the top right corner of the cover with the opening tool.
    • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
  4. Dell Vostro 5510 Speakers Replacement: paso 4, imagen 1 de 3 Dell Vostro 5510 Speakers Replacement: paso 4, imagen 2 de 3 Dell Vostro 5510 Speakers Replacement: paso 4, imagen 3 de 3
    • Lift the cover to remove it from the rest of the laptop.
  5. Dell Vostro 5510 Speakers Replacement, Battery: paso 5, imagen 1 de 1
    • Unscrew the corner and top middle screws (M2x3mm) from the battery with the screwdriver.
  6. Dell Vostro 5510 Speakers Replacement: paso 6, imagen 1 de 3 Dell Vostro 5510 Speakers Replacement: paso 6, imagen 2 de 3 Dell Vostro 5510 Speakers Replacement: paso 6, imagen 3 de 3
    • Lift the battery to remove it
  7. Dell Vostro 5510 Speakers Replacement, Speakers: paso 7, imagen 1 de 2 Dell Vostro 5510 Speakers Replacement, Speakers: paso 7, imagen 2 de 2
    • Remove the 4 mm screw from metal plate above the right-side speaker using a Phillips #0 screwdriver.
  8. Dell Vostro 5510 Speakers Replacement: paso 8, imagen 1 de 1
    • Disconnect the orange cable securing the speaker cords gently using tweezers.
  9. Dell Vostro 5510 Speakers Replacement: paso 9, imagen 1 de 2 Dell Vostro 5510 Speakers Replacement: paso 9, imagen 2 de 2
    • Push the thin white clip back using your finger to release the blue cable.
    • Disconnect the thick blue cable gently using tweezers.
  10. Dell Vostro 5510 Speakers Replacement: paso 10, imagen 1 de 1
    • Disconnect the thin blue cable by gently pulling with tweezers.
  11. Dell Vostro 5510 Speakers Replacement: paso 11, imagen 1 de 1
    • Pull the left speaker up using your hand.
  12. Dell Vostro 5510 Speakers Replacement: paso 12, imagen 1 de 1
    • Pull the right speaker up using your hand.
  13. Dell Vostro 5510 Speakers Replacement: paso 13, imagen 1 de 1
    • Lift the thin cords from under the cable and other components to disconnect them using your hand.
  14. Dell Vostro 5510 Speakers Replacement: paso 14, imagen 1 de 1
    • Pull the white part of the box connecting the speaker cords to the computer using your finger.
Conclusión
Simon
Miembro Desde 02/08/24
157 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 76
