Saltar al contenido principal
Dell Vostro 5510 Battery Replacement
Abril Alejos
Abril Alejos y 2 otros contribuidores
Última actualización: June 12, 2023
Sin estimación
Moderado
Guía de Estudiante Destacada
Introducción
Ir al paso 1
To gain any access to the internal components of the Dell Vostro 15 5510 the back cover will have to be removed. Once the back cover is removed, you can remove and replace the battery. In order to complete this guide, you will need a Phillips #0 screwdriver head and a plastic opening tool. Ensure to unscrew all screws to prevent any battery or battery input damage.
Qué necesitas
Partes
Herramientas
Ver más…
  1. Dell Vostro 5510 Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Power off your laptop before beginning disassembly.
    • Place the laptop so the bottom cover is facing upwards.
  2. Dell Vostro 5510 Battery Replacement: paso 2, imagen 1 de 1
    • Remove the remaining (M2x4mm) screws with the screwdriver.
    • Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
  3. Dell Vostro 5510 Battery Replacement: paso 3, imagen 1 de 3 Dell Vostro 5510 Battery Replacement: paso 3, imagen 2 de 3 Dell Vostro 5510 Battery Replacement: paso 3, imagen 3 de 3
    • Pry open the top left corner of the cover with the opening tool.
    • Pry open the top right corner of the cover with the opening tool.
    • Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
  4. Dell Vostro 5510 Battery Replacement: paso 4, imagen 1 de 3 Dell Vostro 5510 Battery Replacement: paso 4, imagen 2 de 3 Dell Vostro 5510 Battery Replacement: paso 4, imagen 3 de 3
    • Lift the cover to remove it from the rest of the laptop.
  5. Dell Vostro 5510 Battery Replacement, Battery: paso 5, imagen 1 de 1
    • Unscrew the corner and top middle screws (M2x3mm) from the battery with the screwdriver.
  6. Dell Vostro 5510 Battery Replacement: paso 6, imagen 1 de 3 Dell Vostro 5510 Battery Replacement: paso 6, imagen 2 de 3 Dell Vostro 5510 Battery Replacement: paso 6, imagen 3 de 3
    • Lift the battery to remove it
Conclusión
Una persona más ha completado esta guía.
Abril Alejos
Miembro Desde 02/09/23
85 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 717
