Saltar al contenido principal
Dell Vostro 1710 Wi-Fi Card Replacement
Jeremy Campeau
Jeremy Campeau y 3 otros contribuidores
Última actualización: May 23, 2018
7 - 10 minutos
Moderado
Introducción
Ir al paso 1
The Wi-Fi card connects your computer to the internet wirelessy. If you are having trouble connecting to your router or your internet is slow, it might be caused by the Wi-Fi card. This guide will show you step by step on how to replace the Wi-Fi card.
Qué necesitas
Herramientas
  1. Dell Vostro 1710 Wi-Fi Card Replacement, Battery: paso 1, imagen 1 de 2 Dell Vostro 1710 Wi-Fi Card Replacement, Battery: paso 1, imagen 2 de 2
    • Make certain that the power to your laptop is off.
    • Press and slide the two buttons outwards and away from the battery.
  2. Dell Vostro 1710 Wi-Fi Card Replacement: paso 2, imagen 1 de 1
    • Slide the battery away and parallel from the laptop.
  3. Dell Vostro 1710 Wi-Fi Card Replacement: paso 3, imagen 1 de 1
    • Remove the battery from the slot.
  4. Dell Vostro 1710 Wi-Fi Card Replacement, Back Panel: paso 4, imagen 1 de 2 Dell Vostro 1710 Wi-Fi Card Replacement, Back Panel: paso 4, imagen 2 de 2
    • Unscrew the eight 6mm screws with a Philips #1 screw driver.
  5. Dell Vostro 1710 Wi-Fi Card Replacement: paso 5, imagen 1 de 1
    • Lift back cover from the groove on the left side of the cover next to the symbol.
  6. Dell Vostro 1710 Wi-Fi Card Replacement, Wi-Fi Card: paso 6, imagen 1 de 2 Dell Vostro 1710 Wi-Fi Card Replacement, Wi-Fi Card: paso 6, imagen 2 de 2
    • Remove the two 3mm Philips #1 screws from the top of the Wi-Fi card.
  7. Dell Vostro 1710 Wi-Fi Card Replacement: paso 7, imagen 1 de 2 Dell Vostro 1710 Wi-Fi Card Replacement: paso 7, imagen 2 de 2
    • Unclip both black and white wires from the Wi-Fi card.
  8. Dell Vostro 1710 Wi-Fi Card Replacement: paso 8, imagen 1 de 1
    • Gently pull Wi-Fi card out of its position at its angle.
Conclusión
Jeremy Campeau
Miembro Desde 03/20/18
347 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 424
