Dell Studio 1737 RAM Replacement
Introducción
Ir al paso 1RAM can be responsible for bluescreens and other difficult-to-diagnose errors; this guide will instruct you how to replace, remove, or add RAM to your Laptop
Qué necesitas
Slide the battery release slider all the way to the right and push the battery straight out of the back of the computer
Unscrew the 8 Phillips head screws marked in the photo.
Use a plastic opening tool to pry the panel away from the laptop body.
Lift the panel up and away.
Release RAM sticks by pulling clips out in opposite directions of each other.
Pull RAM stick up and out.
2 personas más completaron esta guía.
