Saltar al contenido principal
Dell Studio 1737 Hard Drive Replacement
Joseph Jacavone
Joseph Jacavone y 5 otros contribuidores
Última actualización: January 10, 2025
15 minuto
Fácil
Introducción
Ir al paso 1
This guide will show you how to remove or replace the hard drive (HDD) in a Dell Studio 1737.
The hard drive is where the data of the Dell Studio 1737 resides. You will want to replace the hard drive if it has fails, malfunctions, or if you are updating it for a model with more capacity and speed.
Qué necesitas
Herramientas
  1. Dell Studio 1737 Hard Drive Replacement, Battery: paso 1, imagen 1 de 2 Dell Studio 1737 Hard Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Slide the battery release slider all the way to the right and push the battery straight out of the back of the computer
  2. Dell Studio 1737 Hard Drive Replacement, Back Panel: paso 2, imagen 1 de 3 Dell Studio 1737 Hard Drive Replacement, Back Panel: paso 2, imagen 2 de 3 Dell Studio 1737 Hard Drive Replacement, Back Panel: paso 2, imagen 3 de 3
    • Unscrew the 8 Phillips head screws marked in the photo.
    • Even when the screws are fully detached, they will not come out of the panel.
    • Use a plastic opening tool to pry the panel away from the laptop body.
    • Lift the panel up and away.
  3. Dell Studio 1737 Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 2 Dell Studio 1737 Hard Drive Replacement, Hard Drive: paso 3, imagen 2 de 2
    • Detach Hard drive from SATA connector.
    • Pull hard drive up and out pulling connector out of the way.
    • NOTE: your hard drive may be attached by screws or a bracket. This device had the hard drive just placed under the casing.
Conclusión
3 personas más completaron esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 1,704
