Saltar al contenido principal
Dell Studio 1555 Display Replacement
Qué necesitas
  1. Dell Studio 1555 Display Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off and unplug the laptop.
    • Failure to properly turn off device before handling the battery could result in electrical shock.
    • Flip the laptop so the underside is facing up with the battery closest to you.
  2. Dell Studio 1555 Display Replacement: paso 2, imagen 1 de 3 Dell Studio 1555 Display Replacement: paso 2, imagen 2 de 3 Dell Studio 1555 Display Replacement: paso 2, imagen 3 de 3
    • Slide the locking switch to the left to release the battery.
  3. Dell Studio 1555 Display Replacement: paso 3, imagen 1 de 1
    • Gently pull the battery away from the device.
  4. Dell Studio 1555 Display Replacement, Display: paso 4, imagen 1 de 2 Dell Studio 1555 Display Replacement, Display: paso 4, imagen 2 de 2
    • Insert a plastic opening tool between the bezel and the display cover.
    • Wiggle it to the release the latches.
    • Separate the bezel from the cover.
  5. Dell Studio 1555 Display Replacement: paso 5, imagen 1 de 2 Dell Studio 1555 Display Replacement: paso 5, imagen 2 de 2
    • Remove the four 3 mm screws securing the LCD using the #1 Phillips screwdriver.
  6. Dell Studio 1555 Display Replacement: paso 6, imagen 1 de 1
    • Separate the LCD assembly from the display cover so you will be able to access the webcam cable.
    • Unplug the camera cable.
  7. Dell Studio 1555 Display Replacement: paso 7, imagen 1 de 2 Dell Studio 1555 Display Replacement: paso 7, imagen 2 de 2
    • Place the LCD face down on the top cover.
    • Remove the sticky tape securing the video cable connector.
    • Unplug the video cable from the screen.
  8. Dell Studio 1555 Display Replacement: paso 8, imagen 1 de 3 Dell Studio 1555 Display Replacement: paso 8, imagen 2 de 3 Dell Studio 1555 Display Replacement: paso 8, imagen 3 de 3
    • Remove the LCD from the laptop.
    • Remove the four 3mm screws holding the mounting brackets using the #1 Phillips screwdriver. Two on each side.
    • You will have to transfer the mounting brackets to the new screen.
Conclusión
3 personas más completaron esta guía.
Josh Boone
Miembro Desde 10/10/16
586 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 1,451
