Saltar al contenido principal
Dell Precision 7560 Battery Replacement
Laisha
Laisha y 4 otros contribuidores
Última actualización: February 17, 2025
2 - 5 minutos
Moderado
Introducción
Ir al paso 1
This guide covers how to replace the battery in a Dell Precison 7560. When replacing the battery, make sure to completely power off your device. Not doing so will cause a Fire Hazard. The battery is responsible for powering your device, so it is very hazardous.
Qué necesitas
Partes
Herramientas
Ver más…
  1. Dell Precision 7560 Battery Replacement, Battery: paso 1, imagen 1 de 3 Dell Precision 7560 Battery Replacement, Battery: paso 1, imagen 2 de 3 Dell Precision 7560 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Battery Replacement: paso 2, imagen 1 de 3 Dell Precision 7560 Battery Replacement: paso 2, imagen 2 de 3 Dell Precision 7560 Battery Replacement: paso 2, imagen 3 de 3
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Battery Replacement: paso 3, imagen 1 de 3 Dell Precision 7560 Battery Replacement: paso 3, imagen 2 de 3 Dell Precision 7560 Battery Replacement: paso 3, imagen 3 de 3
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
Conclusión
Una persona más ha completado esta guía.
Laisha
Miembro Desde 02/14/23
205 Reputación
2 Guías creadas
Equipo
Un comentario
Was able to reset a battery that stopped charging with these instructions, appreciate it!
Emiline Doerr - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 21
Ultimos 30 días: 120
Todo El Tiempo: 2,384
