Saltar al contenido principal
Dell Optiplex SX280 Battery Replacement
Tom
Tom y 5 otros contribuidores
Última actualización: August 28, 2019
10 minuto
Moderado
Guía Destacada
Introducción
Ir al paso 1
Replace the Dead Battery on the Motherboard
Qué necesitas
Herramientas
  • Spudger
    Spudger
  1. Dell Optiplex SX280 Battery Replacement, Panel Cover: paso 1, imagen 1 de 1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Battery Replacement: paso 2, imagen 1 de 2 Dell Optiplex SX280 Battery Replacement: paso 2, imagen 2 de 2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Battery Replacement: paso 3, imagen 1 de 2 Dell Optiplex SX280 Battery Replacement: paso 3, imagen 2 de 2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Battery Replacement, Hard Drive: paso 4, imagen 1 de 2 Dell Optiplex SX280 Battery Replacement, Hard Drive: paso 4, imagen 2 de 2
    • Unplug the blue cable that connects the hard drive to the motherboard.
  5. Dell Optiplex SX280 Battery Replacement: paso 5, imagen 1 de 2 Dell Optiplex SX280 Battery Replacement: paso 5, imagen 2 de 2
    • Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view).
  6. Dell Optiplex SX280 Battery Replacement: paso 6, imagen 1 de 1
    • Squeeze the release tabs on either side of the hard drive.
  7. Dell Optiplex SX280 Battery Replacement: paso 7, imagen 1 de 2 Dell Optiplex SX280 Battery Replacement: paso 7, imagen 2 de 2
    • Slide the Hard Drive out while squeezing the tabs.
  8. Dell Optiplex SX280 Battery Replacement, Battery: paso 8, imagen 1 de 1
    • Under the hard drive, there is a circular, silver battery connected to the motherboard.
    • Use a spudger to gently pry the battery from the motherboard.
  9. Dell Optiplex SX280 Battery Replacement: paso 9, imagen 1 de 1
    • Lift the battery out of the motherboard.
  10. Dell Optiplex SX280 Battery Replacement: paso 10, imagen 1 de 3 Dell Optiplex SX280 Battery Replacement: paso 10, imagen 2 de 3 Dell Optiplex SX280 Battery Replacement: paso 10, imagen 3 de 3
    • Upon replacement, simply push the battery into the motherboard.
Conclusión
10 personas más completaron esta guía.
Tom
Miembro Desde 10/04/10
850 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 22-4, Maness Fall 2010 Miembro de Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
Miembros de 4
26 Guías creadas
Un comentario
that particular battery holder looked hard to get out- no pop out lever, thought i’d break it gouging it out!
neverts “itchytastyurr” ennud - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 22
Todo El Tiempo: 11,914
