Saltar al contenido principal
Dell Optiplex GX620 Power Supply Replacement
Kristina
Kristina y 5 otros contribuidores
Última actualización: August 27, 2019
10 - 15 minutos
Moderado
Guía aportada por comunidad
Introducción
Ir al paso 1
You should never try to repair a power supply unit. These are appropriately labeled, "Field Replaceable Units" for a reason. Disassembling a computer power supply unit can seriously harm and even kill you.
Qué necesitas
Herramientas
  1. Dell Optiplex GX620 Power Supply Replacement, How to unplug and discharge before repair: paso 1, imagen 1 de 2 Dell Optiplex GX620 Power Supply Replacement, How to unplug and discharge before repair: paso 1, imagen 2 de 2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 Power Supply Replacement: paso 2, imagen 1 de 2 Dell Optiplex GX620 Power Supply Replacement: paso 2, imagen 2 de 2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 Power Supply Replacement, Dell Optiplex GX620 Side Panel Disassembly: paso 3, imagen 1 de 1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 Power Supply Replacement, Disconnect cables: paso 4, imagen 1 de 3 Dell Optiplex GX620 Power Supply Replacement, Disconnect cables: paso 4, imagen 2 de 3 Dell Optiplex GX620 Power Supply Replacement, Disconnect cables: paso 4, imagen 3 de 3
    • Gently disconnect the power cables from the motherboard and drives.
  5. Dell Optiplex GX620 Power Supply Replacement, Remove the screws: paso 5, imagen 1 de 1
    • Remove the four screws that attach the power supply on the back of the chassis.
    • Do not remove any screws that are not highlighted in red.
  6. Dell Optiplex GX620 Power Supply Replacement, Press the release button: paso 6, imagen 1 de 1
    • Press the blue release button. This is located on the floor of the computer chassis right in front of the power supply.
  7. Dell Optiplex GX620 Power Supply Replacement, Remove the power supply: paso 7, imagen 1 de 1
    • Remove the unconnected power supply by sliding it towards the front of the computer. Next, lift it up out of the chassis.
Conclusión
10 personas más completaron esta guía.
Kristina
Miembro Desde 09/03/14
210 Reputación
7 Guías creadas
Equipo
Pasco Hernando, Team 5-1, Prince Fall 2014 Miembro de Pasco Hernando, Team 5-1, Prince Fall 2014
PHSC-PRINCE-F14S5G1
10 Miembros
15 Guías creadas
3 comentarios
Thanks, I followed the instructions, the replacement of the power supply unit was more simple than I expected
George
geotech78 - Contestar
i replaced that but not repair this
Muhammad Qasim - Contestar
At post Madasanal TQ disk bijapur
sidaray - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 33
Todo El Tiempo: 7,286
