Saltar al contenido principal
Dell Optiplex GX620 Network Adapter Replacement
Kristina
Kristina y 4 otros contribuidores
Última actualización: August 27, 2019
10 minuto
Fácil
Guía aportada por comunidad
Introducción
Ir al paso 1
This PCI network adapter enables users to connect to the internet typically though an Ethernet cable. You will not be able to obtain a connection if this device is faulty.
  1. Dell Optiplex GX620 Network Adapter Replacement, How to unplug and discharge before repair: paso 1, imagen 1 de 2 Dell Optiplex GX620 Network Adapter Replacement, How to unplug and discharge before repair: paso 1, imagen 2 de 2
    • Power down your PC and remove the power cord from the back.
  2. Dell Optiplex GX620 Network Adapter Replacement: paso 2, imagen 1 de 2 Dell Optiplex GX620 Network Adapter Replacement: paso 2, imagen 2 de 2
    • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  3. Dell Optiplex GX620 Network Adapter Replacement, Dell Optiplex GX620 Side Panel Disassembly: paso 3, imagen 1 de 1
    • With the computer standing upright, firmly pull on the tab at the back of the computer.
    • When the side panel pops free, gently pull the panel away from the computer.
    • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  4. Dell Optiplex GX620 Network Adapter Replacement, Freeing the PCI slots: paso 4, imagen 1 de 2 Dell Optiplex GX620 Network Adapter Replacement, Freeing the PCI slots: paso 4, imagen 2 de 2
    • Gently push the release tab on the card retention latch from the inside to pivot the latch open. The latch will remain in the open position
  5. Dell Optiplex GX620 Network Adapter Replacement, Removing the Network Adapter: paso 5, imagen 1 de 1
    • With your free hand, gently squeeze the sides of the card. Pull upwards to release it from the tab slots that hold it in place.
Conclusión
2 personas más completaron esta guía.
Kristina
Miembro Desde 09/03/14
210 Reputación
7 Guías creadas
Equipo
Pasco Hernando, Team 5-1, Prince Fall 2014 Miembro de Pasco Hernando, Team 5-1, Prince Fall 2014
PHSC-PRINCE-F14S5G1
10 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 19
Todo El Tiempo: 2,326
