Dell Latitude E7470 Speakers Replacement
Introducción
Ir al paso 1The Dell Latitude E7470 laptop's internal speaker units are responsible for audio output and are paired for stereo sound. If one or both units fail, sound output is compromised. Signs of a failing speaker include decreased volume, distortion, or garbled sound. The left and right speakers are hardwired together and sold as a single unit.
Qué necesitas
Herramientas
Remove the eight 4 mm screws on the back cover using a Phillips #0 screwdriver.
Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
