Saltar al contenido principal
Dell Latitude E7440 Hard Drive Replacement
Akash Kedia
Akash Kedia y 3 otros contribuidores
Última actualización: October 15, 2020
15 minuto
Fácil
Introducción
Ir al paso 1
If you are running low on storage space or your hard drive has failed, it is likely time to replace it. Replacing your hard drive (Latitude E7440 base models contain SSHDs) with a faster SSD will greatly improve the overall speed of your device as well. This guide will outline the steps on how to replace your drive.
Qué necesitas
Kits de reparación
Estos kits contienen todas las piezas y herramientas necesarias para completar esta guía.
Partes
Herramientas
Ver más…
  1. Dell Latitude E7440 Hard Drive Replacement, Prepare the laptop: paso 1, imagen 1 de 1
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 Hard Drive Replacement, Release the battery: paso 2, imagen 1 de 3 Dell Latitude E7440 Hard Drive Replacement, Release the battery: paso 2, imagen 2 de 3 Dell Latitude E7440 Hard Drive Replacement, Release the battery: paso 2, imagen 3 de 3
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 Hard Drive Replacement, Remove the battery: paso 3, imagen 1 de 1
    • Lift the battery by the top, away from the laptop body.
  4. Dell Latitude E7440 Hard Drive Replacement, Hard Drive: paso 4, imagen 1 de 3 Dell Latitude E7440 Hard Drive Replacement, Hard Drive: paso 4, imagen 2 de 3 Dell Latitude E7440 Hard Drive Replacement, Hard Drive: paso 4, imagen 3 de 3
    • Remove two M2 x 3mm Phillips #0 screws from the base cover.
    • Slide the service tray using the middle stand offs to then be able to lift the tray off.
  5. Dell Latitude E7440 Hard Drive Replacement: paso 5, imagen 1 de 2 Dell Latitude E7440 Hard Drive Replacement: paso 5, imagen 2 de 2
    • Remove four M2 x 3mm Phillips #0 screws from the hard drive cage.
    • Remove the hard drive cage by lifting it off the laptop.
    • The hard drive cage is not pictured here, but the screws will be in these locations.
  6. Dell Latitude E7440 Hard Drive Replacement: paso 6, imagen 1 de 2 Dell Latitude E7440 Hard Drive Replacement: paso 6, imagen 2 de 2
    • Disconnect the hard drive connector from the top of the drive.
    • iFixit's device came without a hard drive to picture. Your device will have a component connected to the thin, black connector.
    • The hard drive connector can be removed from the laptop body to make replacement easier.
Conclusión
4 personas más completaron esta guía.
Akash Kedia
Miembro Desde 01/24/19
1,445 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S2-G5, White Winter 2019 Miembro de Cal Poly, Team S2-G5, White Winter 2019
CPSU-WHITE-W19S2G5
4 Miembros
5 Guías creadas
3 comentarios
Hi, my problem is the opposite, I have an hard drive but seems like my HDD connector doesn't plug in the small port. I can send you a pic, I need help
†Winterfall† - Contestar
I want to use a Seagate hard disk, but when I start it, it demands me a password. Can you help me in this case please?
Aldoni JB - Contestar
It sounds like your BIOS is locked to only work with that hard drive
Magnus Vacuum -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 28
Ultimos 30 días: 80
Todo El Tiempo: 12,152
