Saltar al contenido principal
Dell Latitude E7440 CMOS Battery Replacement
Akash Kedia
Akash Kedia y otro contribuidor
Última actualización: March 6, 2019
10 minuto
Fácil
Introducción
Ir al paso 1
If your laptop refuses to boot into the operating system following a BIOS update, your hard drive is reported as not found, or the time on your computer’s clock is always wrong after booting up, the battery powering the CMOS may be defective or out of charge. Thankfully, Dell has made replacing this battery on the Latitude E7440 easy. This guide will outline how to remove this battery for replacement.
Qué necesitas
Herramientas
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Dell Latitude E7440 CMOS Battery Replacement, Prepare the laptop: paso 1, imagen 1 de 1
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 CMOS Battery Replacement, Release the battery: paso 2, imagen 1 de 3 Dell Latitude E7440 CMOS Battery Replacement, Release the battery: paso 2, imagen 2 de 3 Dell Latitude E7440 CMOS Battery Replacement, Release the battery: paso 2, imagen 3 de 3
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 CMOS Battery Replacement, Remove the battery: paso 3, imagen 1 de 1
    • Lift the battery by the top, away from the laptop body.
  4. Dell Latitude E7440 CMOS Battery Replacement, CMOS Battery: paso 4, imagen 1 de 2 Dell Latitude E7440 CMOS Battery Replacement, CMOS Battery: paso 4, imagen 2 de 2
    • Remove two M2 x 3mm Phillips #0 screws from the base cover.
  5. Dell Latitude E7440 CMOS Battery Replacement: paso 5, imagen 1 de 2 Dell Latitude E7440 CMOS Battery Replacement: paso 5, imagen 2 de 2
    • Slide the base cover down slightly and remove it.
  6. Dell Latitude E7440 CMOS Battery Replacement: paso 6, imagen 1 de 3 Dell Latitude E7440 CMOS Battery Replacement: paso 6, imagen 2 de 3 Dell Latitude E7440 CMOS Battery Replacement: paso 6, imagen 3 de 3
    • Position your nylon spudger on the edge of the white connector, in between the connector and the port.
    • Pull back on the connector until the plastic head disconnects from the port on the laptop body.
    • If the connector is stuck, move the broader end of the spudger back and forth across the connector to slowly loosen the connection.
  7. Dell Latitude E7440 CMOS Battery Replacement: paso 7, imagen 1 de 1
    • Separate the wrapped battery stack from the body by pulling up the wire.
    • You may need to use the flat end of the nylon spudger to separate the battery.
    • The stack is attached using glue, so you might hear a pop when removing it.
    • Reapplying an adhesive to the bottom of the battery is recommended, although not necessary, to keep it in place.
Conclusión
6 personas más completaron esta guía.
Akash Kedia
Miembro Desde 01/24/19
1,445 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S2-G5, White Winter 2019 Miembro de Cal Poly, Team S2-G5, White Winter 2019
CPSU-WHITE-W19S2G5
4 Miembros
5 Guías creadas
2 comentarios
You list no part number for the replacement battery. Do we know the part number? I looked on Dell's website and find nothing. Otherwise, nice write-up!
jess13j - Contestar
@jess13j, battery is a CR2032 coin cell.
senzog - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 34
Ultimos 30 días: 105
Todo El Tiempo: 14,211
