Saltar al contenido principal
Dell Latitude E7270 RAM Replacement
Jacob Clement
Jacob Clement y 2 otros contribuidores
Última actualización: January 9, 2025
15 minuto
Moderado
Introducción
Ir al paso 1
Use this guide to replace broken RAM modules on your Dell Latitude E7270.
The ram modules are used throughout all processes when active. They do not require a lot of power so they primarily fail due to onboard shorts or physically get damaged. Broken RAM modules can render your computer extremely slow or useless.
Before using this guide, check out the troubleshooting page to see if your symptoms match any that represent bad RAM modules.
You can also use this guide to upgrade your RAM for more a higher memory configuration.
This replacement requires a #00 Phillips head screwdriver.
NOTE: This guide requires removal of the back panel and battery. The extra prerequisite guide steps are included in this guide.
Qué necesitas
Herramientas
  1. Dell Latitude E7270 RAM Replacement, Back Panel: paso 1, imagen 1 de 1
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 RAM Replacement: paso 2, imagen 1 de 1
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
  3. Dell Latitude E7270 RAM Replacement: paso 3, imagen 1 de 1
    • Lift and remove the panel.
  4. Dell Latitude E7270 RAM Replacement, Battery: paso 4, imagen 1 de 1
    • Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
  5. Dell Latitude E7270 RAM Replacement: paso 5, imagen 1 de 2 Dell Latitude E7270 RAM Replacement: paso 5, imagen 2 de 2
    • Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
  6. Dell Latitude E7270 RAM Replacement: paso 6, imagen 1 de 1
    • Remove the battery completely by grabbing an edge and pulling up on the battery.
  7. Dell Latitude E7270 RAM Replacement, RAM: paso 7, imagen 1 de 1
    • Locate the 2 RAM modules above where the battery would be.
    • The two blue RAM modules used in the photo may vary in color from your device.
  8. Dell Latitude E7270 RAM Replacement: paso 8, imagen 1 de 1
    • While the RAM is still seated, push the silvered clips either side of each stick outwards. There should be some obvious upward movement from each stick.
  9. Dell Latitude E7270 RAM Replacement: paso 9, imagen 1 de 1
    • Firmly grab each RAM with your fingers and pull them away from you to remove them.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 19
Ultimos 30 días: 32
Todo El Tiempo: 1,011
